mqtt DNS lookup failed err=202 res=0x0
xcmonline
Postby xcmonline » Sun Dec 19, 2021 2:17 pm
nvs_flash_init();
    tcpip_adapter_init();
    ESP_ERROR_CHECK( esp_event_loop_init(event_handler, NULL) );
    wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
    ESP_ERROR_CHECK( esp_wifi_init(&cfg) );
    ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
    ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
    wifi_config_t sta_config = {
        .sta = {
            .ssid = CONFIG_ESP_WIFI_SSID,
            .password = CONFIG_ESP_WIFI_PASSWORD,
            .bssid_set = false
    ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_STA, &sta_config) );
    ESP_ERROR_CHECK( esp_wifi_start() );
    ESP_ERROR_CHECK( esp_wifi_connect() );
    //MQTT
    const esp_mqtt_client_config_t mqtt_cfg = {
    	.client_id="1234567",
        .host = "mqtt://192.168.3.6",//服务器IP地址 默认端口 1883
	.port = 1883
    esp_mqtt_client_handle_t client = esp_mqtt_client_init(&mqtt_cfg);
    esp_mqtt_client_register_event(client, ESP_EVENT_ANY_ID, mqtt_event_handler, client);
    esp_mqtt_client_start(client);
在运行时显示:
E (5807) TRANS_TCP: DNS lookup failed err=202 res=0x0
E (5807) MQTT_CLIENT: Error transport connect
但wifi看了路由器是连接成功的。
ESP_YJM
Re: mqtt DNS lookup failed err=202 res=0x0
Postby ESP_YJM » Mon Dec 20, 2021 7:08 am
mqtt_cfg 里把 host 改成 uri
xcmonline
Postby xcmonline » Mon Dec 20, 2021 1:33 pm
修改了后报:
E (5807) TRANS_TCP: [sock=54] connect() error: Host is unreachable
ESP_YJM
Postby ESP_YJM » Tue Dec 21, 2021 8:19 am
确认下这个地址是否可达?
xcmonline
Postby xcmonline » Tue Dec 21, 2021 1:30 pm
都是在同一局域网内,同一台路由器,ip与端口使用其他mqtt软件正常连接。
xcmonline
Postby xcmonline » Tue Dec 21, 2021 2:48 pm
已解决
Goodboy~
Postby Goodboy~ » Wed Sep 21, 2022 12:56 pm
怎么解决的呀 说一下呀
mw1472005
Postby mw1472005 » Thu Apr 20, 2023 4:07 am
简单点说,这个错误是因为你输入了错误的地址或端口导致的,所以解决办法就是先确认一下自己输入的地址是否正确就可以了
Users browsing this forum: No registered users and 71 guests
