with my application I'd like to be conform to the Automation IO Bluetooth GATT profile. I'd like to build a Automation IO GATT service which is decribed here: https://www.bluetooth.org/DocMan/handle ... _id=304972
But unfortunately the UUID's for this service are not in the esp_gatt_defs.h file. I could define it by myself but I also need the number of digitals GATT descriptor: https://www.bluetooth.com/specification ... gitals.xml
If I try to add such a descriptor it's ignored in the btc_gatts_act_create_attr_tab function because there is no case for handling this descriptor: https://github.com/espressif/esp-idf/bl ... tts.c#L337
I've used the gatt_server_service_table example as a starting point for my Bluetooth project.
Could you add support for the Automation IO Bluetooth GATT profile?
Automation IO Bluetooth GATT profile support
Users browsing this forum: Bing [Bot] and 73 guests
