[Prerelease] ESP32S3WROOM1 & ESP32S3WROOM1U Datasheet
Hi Folks
ESP32S3WROOM1 & ESP32S3WROOM1U Datasheet Pre-release v0.5.1.
It is the preliminary for chip revision 0
[English Version for the First Step ] i will update the post here if the Datasheet | 技术规格书 / News is online at espressif too
rudi
btw:
ESP32-S3-WROOM example on the new ESP32-S3-DEVKITC-1-N8 | ESP32-S3-DEVKITC-1-N8R2
rudi
btw:
- ESP32-S3-DEVKITC-1-N8[R2]
- ESP32-S3-DEVKITC-1-N8.png (185.92 KiB) Viewed 49094 times
Re: [Prerelease] ESP32S3WROOM1 & ESP32S3WROOM1U Datasheet
Will there be an ESP32-S3 mini module?
in any case -
modules from the ESP32, ESP32-S3, and ESP32-C3 series will also be included in Espressif's MINI series.
FYI:
ESP32-S3-USB-OTG with ESP32-S3-MINI is allready available.
i also use Mini Serie's at the Stickley.
Rudi, do you know the difference between ESP32-S3-DevKitC-1-N8, ESP32-S3-DevKitC-1-N8R2 and ESP32-S3-DevKitC-1-N8R8?
Thanks in advance!
Thanks in advance!
- ESP_krzychb
- Contact:
Hi mlinaje,
The difference is the size of flash and PSRAM memory, please see https://products.espressif.com/#/produc ... roducts%22:[%22Module%22],%22Series%22:[%22ESP32-S3%22]}
(Checkout out "ESP32-S3" and "module" in the selector. You may need to widen "MPN" column to see the module name with similar codes.)
hi mlinaje
you got already replied, I also add my "mustard" ..
here are a few additions
in this case to have a certain flash type (H for High Temperature[105°C] or N for Normal [85°C]) and Digit for the size: N8 for 8MB Flash (normal)
in this case to have a certain extra RAM: Digit for the size 2MB, 8MB, 16MB. Note there are Quad SPI and Octal SPI version.
if you have limits in your pcb : note that Octal version needs more IO
ESP32-S3-DevKitC-1-N8 ( normal flash 8 MB )
ESP32-S3-DevKitC-1-N8R2 (normal flash 8 MB and extra psram 2 MB )
ESP32-S3-DevKitC-1-N8R8 (normal flash 8 MB and extra psram 8 MB )
In this case DevKitC is based on WROOM
Note: there is also a DevKitM - this is based on the MINI
Overview:
hope this helps
rudi ;-
ps: added the Espressif's_Chip-Packing_Information
- Espressif's_Chip-Packing_Information__EN.pdf
- (1.85 MiB) Downloaded 1191 times
update 2021-Oct-29
Hi Folks,
ESP32-S3-WROOM-1 & ESP32-S3-WROOM-1U Datasheet
This document introduces the specifications of ESP32-S3-WROOM-1 and ESP32-S3-WROOM-1U hardware, including overview, pin definitions, functional description, peripherals, and electrical characteristics, etc.
v0.6 2021.10.29
ESP32-S3-WROOM-1 & ESP32-S3-WROOM-1U 技术规格书
本文档为用户提供 ESP32-S3-WROOM-1 和 ESP32-S3-WROOM-1U 模组的技术规格信息。
v0.6 2021年10月29日
also for History here attached EN and CN Version
EN
CN
Document Updates
Please always refer to the latest version on https://www.espressif.com/en/support/download/documents.
Documentation Change Notification
Espressif provides email notifications to keep customers updated on changes to technical documentation.
Please subscribe at www.espressif.com/en/subscribe
文档版本
请至乐鑫官网 https://www.espressif.com/zh-hans/suppo ... -documents 下载最新版本文档。
文档变更通知
用户可以通过乐鑫官网订阅页面 www.espressif.com/zh-hans/subscribe 订阅技术文档变更的电子邮件通知。
rudi
Hi Folks,
v0.6 2021.10.29
v0.6 2021年10月29日
EN
CN
Document Updates
文档版本
文档变更通知
rudi
Is the ESP32-S3 "mini" module datasheet available yet?
s3 mini is still preliminary v0.2.1 but not yet public online there
products/modules | esp product selector | espressif documents
but heard, there will be an updated one on official website very soon dmaxben.
ESP32-S3 MINI -> viewtopic.php?f=5&t=24418
Users browsing this forum: No registered users and 18 guests
