esp_http_client.h: No such file or directory
I am having a weird issue with ESP-IDF. In my project directory if I call esp_http_client from a main or from a library in the same directory It works. But when I shift the library to somewhere else, this particular library can not be imported. I already got RFID, gpio, and wifi libraries set up in my "lib" directory and works well. Any ideas on how I can solve this problem? No issues in CMakeLists because all the other libraries are working. I have tried many ways but I can't progress any further. The examples of http_clients in IDF works because everything is in the main file and my configuration files are derived from the template project of EPS-IDF. If anyone knows please help me to resolve this issue. Thank you in advance.
- Screenshot 2021-10-17 213429.png (13.77 KiB) Viewed 10835 times
Re: esp_http_client.h: No such file or directory
You say 'no issues in the CMakeLists.txt file'... just to make sure, you have esp_http_client in the REQUIRES and/or PRIV_REQUIRES there? If in doubt, can you post the file?
"includePath": [
"${config:idf.espIdfPath}/components/**",
"${config:idf.espIdfPathWin}/components/**",
"${config:idf.espAdfPath}/components/**",
"${config:idf.espAdfPathWin}/components/**",
"${workspaceFolder}/**"
my directory is like this.
project
- .vscode
- libs
- main
- CMakeLists.txt
I already created 3 libraries for other tasks. everything works fine. but I simply can't import http_client library inside the lib folder. I can only realize it in the main folder.
Sorry, but that doesn't answer any of the questions I asked... Can you specifically post the contents of the CMakeLists.txt in the component where you are trying to use esp_http_client?
home directory
under http directory
Hope this is what you were asking for?
cmake_minimum_required(VERSION 3.5)
set(EXTRA_COMPONENT_DIRS lib)
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
idf_component_register(
SRCS "HTTP.cpp"
INCLUDE_DIRS .
Yep. You're missing a REQUIRES/PRIV_REQUIRES line, as I said before. Change the CMakeLists.txt file in the http dir to
SRCS "HTTP.cpp"
INCLUDE_DIRS .
REQUIRES esp_http_client
Thank you. That solved. I have two questions to ask.
1. This is my includes in WIFI library which resides in the same directory as of Http.
but this didn't ask me to add anything to REQUIRES. Why is that?
2. How can I add more REQUIRES? Because I also included cJSON.h but it says no such file. I tried few methods like space separation, comma separation. but it didn't catch that. Thank you
#include "freertos/event_groups.h"
#include "esp_log.h"
#include "esp_event.h"
#include "esp_wifi.h"
I don't know the answer to your first question... On the second one: the delimiter generally is a space, but do note that the thing you need to enter is a component name, which is the same as the base directory the component lives in. For instance, cJSON.h lives in esp-idf/components/json/cJSON/cJSON.h. The component name in this case would be 'json', so you'd need to fill that in.
thank you so much for your help. I learned a lot from you
No problem, glad I could help!
Users browsing this forum: No registered users and 178 guests
