ESP32 GPIO pin options for USR-ES1
Eiskuh
Postby Eiskuh » Wed Sep 08, 2021 2:05 pm
Hi All.
I need some help regarding GPIO pin option for connecting a W5500 Ethernet module to an ESP32 dev kit. I am planing on building a controller for my home automation which connects to my home server via ethernet. I am a not sure regarding the pins and if I understand the documentation correctly which states that one can define most of the ESP32 pins via Software.
Q: Can I connect the Ethernet module USR-ES1 to ESP32 as follows?
ESP32 ------- USR-ES1
GPIO33 ------> Miso
GPIO32 ------> Reset
GPIO26 ------> SCLK
GPIO25 ------> Mosi
GPIO27 ------> SCS (Chip select)
Reason for these GPIO choice is that I want to keep the PCB breakout board simple, single sided with no trace crossing where possible.
Regards
Mike
ESP_LJH
Re: ESP32 GPIO pin options for USR-ES1
Postby ESP_LJH » Thu Sep 09, 2021 3:20 am
In fact, you could use ang unused GPIO as SPI, so the pins you select are acceptable.
Eiskuh
Postby Eiskuh » Thu Sep 09, 2021 10:57 am
Great. Thanks
zeboxer
Postby zeboxer » Thu Aug 24, 2023 6:33 am
Hi All!
I have ESP32-S3-WROOM-1 (ESP32N4R8) and try connect to the USR-ES1 ethernet module.
I use pins:
[ESP32-S3] --- [USR-ES1]
IO3   <-->     MOSI
IO4  <-->      SCLK
IO5   <-->     SCSn
IO6   <-->     INTn
IO7   <-->     MISO
IO8   <-->     RESETn
3V    <-->     3V
GND <-->   GND
Are these pins compatible for connection with the module?
Does ESP32-S3 support Ethernet MAC or I should use another
When I try connect to it with `basic` example i get error:
... version mismatch 0x04 instead 0x00 ...
Could you help me with wiring and work for this ethernet module (USR-ES1)?
