For some time I've been trying to solve this problem and I can't, the fact is. I have an esp32 saving settings, and it gets an ISR from LoRa. Despite semaphoro deals, apparently, the act of happening the ISR while manipulating the flash is a problem.
Any suggestion?
PC: 0x40008150
EXCVADDR: 0x00000000
Decoding stack results
0x40081321: RH_RF95::handleInterrupt() at /home/perotto/Arduino/libraries/RadioHead/RH_RF95.cpp line 347
0x4008142a: RH_RF95::isr0() at /home/perotto/Arduino/libraries/RadioHead/RH_RF95.cpp line 359
0x40081495: __onPinInterrupt at /home/perotto/.arduino15/packages/esp32/hardware/esp32/1.0.4/cores/esp32/esp32-hal-gpio.c line 220
0x40094097: esp_rom_spiflash_read_status at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spi_flash/spi_flash_rom_patch.c line 261
0x400940ce: esp_rom_spiflash_wait_idle at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spi_flash/spi_flash_rom_patch.c line 35
0x4009416d: esp_rom_spiflash_erase_sector_internal at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spi_flash/spi_flash_rom_patch.c line 121
0x40094602: esp_rom_spiflash_erase_sector at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spi_flash/spi_flash_rom_patch.c line 451
0x40087f89: spi_flash_erase_range at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spi_flash/flash_ops.c line 237
0x40162a2e: esp_partition_erase_range at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spi_flash/partition.c line 294
0x4010371b: spiffs_api_erase at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spiffs/spiffs_api.c line 58
0x40104fde: spiffs_erase_block at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spiffs/spiffs/src/spiffs_nucleus.c line 236
0x40103b39: spiffs_gc_erase_block at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spiffs/spiffs/src/spiffs_gc.c line 15
0x4010467a: spiffs_gc_check at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spiffs/spiffs/src/spiffs_gc.c line 168
0x40106a6e: spiffs_object_truncate at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spiffs/spiffs/src/spiffs_nucleus.c line 1736
0x40102d6a: SPIFFS_open at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spiffs/spiffs/src/spiffs_hydrogen.c line 275
0x4010211a: vfs_spiffs_open at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/spiffs/esp_spiffs.c line 451
0x401307ee: esp_vfs_open at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/vfs/vfs.c line 388
0x4013313a: _fopen_r at ../../../.././newlib/libc/stdio/fopen.c line 141
0x401331c9: fopen at ../../../.././newlib/libc/stdio/fopen.c line 181
0x400e70ea: VFSFileImpl::VFSFileImpl(VFSImpl*, char const*, char const*) at /home/perotto/.arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/FS/src/vfs_api.cpp line 263
0x400e741f: std::__shared_ptr ::__shared_ptr , VFSImpl*&, char const*, char const*&>(std::_Sp_make_shared_tag, std::allocator const&, VFSImpl*&, char const*&&, char const*&) at /home/perotto/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/xtensa-esp32-elf/include/c++/5.2.0/ext/new_allocator.h line 120
0x400e76ad: VFSImpl::open(char const*, char const*) at /home/perotto/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/xtensa-esp32-elf/include/c++/5.2.0/bits/shared_ptr.h line 319
0x400e6d74: fs::FS::open(char const*, char const*) at /home/perotto/.arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/FS/src/FS.cpp line 191
0x400da562: writeFile(fs::FS&, char const*, char const*, unsigned short) at /home/perotto/Documentos/GitHub/STU-MB/fileSystem.ino line 128
0x400dd965: saveConfig (fs::FS&, char const*, CF_STU_4s*) at /home/perotto/Documentos/GitHub/STU-MB/setupSystem.ino line 445
0x400de0cb: saveAllConfig() at /home/perotto/Documentos/GitHub/STU-MB/setupSystem.ino line 113
0x400de37b: receiveSyncEnd() at /home/perotto/Documentos/GitHub/STU-MB/LoRaProcess.ino line 390
0x400e4415: processFromBomba(cadastro_t*) at /home/perotto/Documentos/GitHub/STU-MB/LoRaProcess.ino line 71
0x400e45ff: processLoraReceive() at /home/perotto/Documentos/GitHub/STU-MB/LoRaProcess.ino line 23
0x400e4fee: doLoRaTask(void*) at /home/perotto/Documentos/GitHub/STU-MB/taskLora.ino line 77
0x40089cf5: vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c line 143
extensive FS / ISR problem
Re: extensive FS / ISR problem
Sounds like that ISR is marked as being entirely in IRAM while in fact, it's not. Hard to say without the full error or the code.
Do all sub-function calls also need to be in IRAM?ESP_Sprite wrote: ↑Thu Jul 29, 2021 1:42 amSounds like that ISR is marked as being entirely in IRAM while in fact, it's not. Hard to say without the full error or the code.
Yes. All data accessed also needs to be in RAM. Effectively, if your marked-as-in-IRAM ISR touches the flash (or psram, in available) in any way while the flash is erased or written, you'll get this.
Thank you very much, it enlightened me a lot. I was able to understand the problem, now develop a solution.
Users browsing this forum: No registered users and 163 guests
