Hi guys
I've been working on a gaming project that utilizes the ili9341 and almost any MCU. The library is an easy platform for creating 8-bit to 32-bit games. I've got several different libraries but I want to incorporate ESP32 into libraries. Thanks to another member I was able to find this page.................
https://github.com/search?q=esp32+ili93 ... positories
I'm interested in the examples and new esp32 drivers by loboris's but I'm not seeing how to use them. There is usually a .ino file in all the arduino stuff I use. Where do I put the new master drivers? Would I put them in my ili9341 library or do I stick them in the esp32 hardware folders some where. From the times listed it on the ili9341_esp32 driver page it seems to be way faster than the teensy's I've been using.
But what I really need is a frame buffer.
Any way how do I use this stuff?
Also how do include files from the esp32/cores/esp32/file? I tried all three plus the file, then cores/esp32/file and esp32/file but arduino refuses to find the file. I need pgmspace and sleep
Laboris ESP32_new_spi_master_example help
Fear is the mind killer.......
GameR the DIY iot gaming device that does more......
https://github.com/Duhjoker/GameR-Iot_ESP
Re: Laboris ESP32_new_spi_master_example help
Also....
What are HAL locks and how do I disable them?
Hello!????
What problem do you have that causes you to need to disable HAL locks, even if you do not even know what they are?
It said it was faster. But right now I'm just trying to get a picture to show up on my ili9341 TFT. The board I'm using doesn't have much documentation that I can find and I've been going else where but they ended thier knowledge last week.
Wrt Arduino, I can't help you, I fear. If you just want to get something to work, however, there's a SPI-master example in the esp-idf that controls an ILI9341 LCD. Maybe you can use that to check your hardware.
Would you happen to know a dealer thst sells the regular boards you manufacture but with out pins soldered to the board?
Users browsing this forum: Google [Bot] and 82 guests
