How to increase .bss size for ULP?
jshnaidm
Postby jshnaidm » Sun Jul 18, 2021 9:52 pm
Hi. I'm using the vscode extension to program and build my project. I've used the SDK Configuration editor to increase the RTC slow memory reserved for the coprocessor, but regardless of how high I put it, it always tells me that the ram region overflows by 64 bytes:
[3/83] Performing build step for 'ulp_main'
FAILED: esp-idf/main/ulp_main-prefix/src/ulp_main-stamp/ulp_main-build esp-idf/main/ulp_main/ulp_main.bin esp-idf/main/ulp_main/ulp_main.ld esp-idf/main/ulp_main/ulp_main.h esp-idf/main/ulp_main/ulp_main.map esp-idf/main/ulp_main/ulp_main.sym esp-idf/main/ulp_main/esp32.ulp.ld esp-idf/main/ulp_main/ulp_main
cmd.exe /C "cd /D D:\Projects\moist_plants_idf\build\esp-idf\main\ulp_main && C:\Users\jacob\.espressif\tools\cmake\3.16.4\bin\cmake.exe --build D:/Projects/moist_plants_idf/build/esp-idf/main/ulp_main --target build"
[1/4] Linking ASM executable ulp_main
FAILED: ulp_main
cmd.exe /C "cd . && esp32ulp-elf-ld                                   -A elf32-esp32ulp -nostdlib CMakeFiles/ulp_main.dir/adc.ulp.S.obj -o ulp_main  -TD:/Projects/moist_plants_idf/build/esp-idf/main/ulp_main/esp32.ulp.ld  -Map=D:/Projects/moist_plants_idf/build/esp-idf/main/ulp_main/ulp_main.map && cd ."
esp32ulp-elf-ld: ulp_main section `.bss' will not fit in region `ram'
esp32ulp-elf-ld: region `ram' overflowed by 64 bytes
[4/83] Linking C static library esp-idf\esp_serial_slave_link\libesp_serial_slave_link.a
The terminal process "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -Command cmake --build ." terminated with exit code: 1.
I can confirm that my sdkconfig has at least 2kb reserved for the ULP:
CONFIG_ULP_COPROC_ENABLED=y
CONFIG_ULP_COPROC_RESERVE_MEM=2048
How do I allocate more memory for my ulp program? Thanks in advance for any help.
louis___
Re: How to increase .bss size for ULP?
Postby louis___ » Mon Jul 19, 2021 9:46 am
I'm also facing this issue. I see this issue both in Eclipse and using the cmdline tool. I'm using IDF 4.3. My colleague who doesn't see this issue is using 4.2. No matter how I change the sdk config file (either though the Eclipse json file or the cmdline menuconfig) I still see this issue. I don't really want to change version.
felmue
Postby felmue » Mon Jul 19, 2021 5:12 pm
Hello @jshnaidm
when I change the RTC slow memory value via 'menuconfig' I see it in two places:
sdkconfig:CONFIG_ESP32_ULP_COPROC_RESERVE_MEM=2048
sdkconfig:CONFIG_ULP_COPROC_RESERVE_MEM=2048
It looks like some options have been deprecated and replaced with others: https://docs.espressif.com/projects/esp ... placements
Maybe that is the issue you are facing?
Felix
jshnaidm
Postby jshnaidm » Mon Jul 19, 2021 11:32 pm
Hello @jshnaidm
Felix
Ah, I should have included both, but I have those options configured as well.
CONFIG_ESP32_ULP_COPROC_ENABLED=y
ESP-Marius
Postby ESP-Marius » Tue Jul 20, 2021 1:46 am
Should be the correct way of increasing it. Any chance CONFIG_ESP32S2_ULP_COPROC_RESERVE_MEM is defined in your sdkconfig as well? That could potentially overwrite the setting.
Are you able to provide a simple example that reproduce this behaviour? If so I'd be happy to take a look at what's going wrong.
jshnaidm
Postby jshnaidm » Tue Jul 20, 2021 6:09 am
In the process of committing my code to a github repository to share my example, I cleaned my project. After I made the commit I tried rebuilding, and I can't reproduce the error anymore. I didn't have CONFIG_ESP32S2_ULP_COPROC_RESERVE_MEM defined or anything. Odd! Doing a clean build has solved so many problems for me in the past, I don't know why I didn't try it earlier.
Thanks for the help.
Jacob
Users browsing this forum: Bing [Bot] and 93 guests
