how to disable server validation (CA)
jakarman12
Postby jakarman12 » Tue Jan 26, 2021 9:37 pm
Hello guys,
I'm testing the HTTPs module with esp_http_client but I've gotten a bit stuck.
I want to make a request using HTTPS and without validating the server's CA, using the CA's validation works fine, but when I want it not to check the CA (using .skip_cert_common_name_check = true), the program returns the following error. (It seems that it continues to validate the ca :shock: ).
esp-idf: v4.3-dev-2586-g526f68239
=================== ERROR ===========================
E (5001) esp-tls-mbedtls: No server verification option set in esp_tls_cfg_t structure. Check esp_tls API reference
E (5001) esp-tls-mbedtls: Failed to set client configurations
E (5011) esp-tls: create_ssl_handle failed
E (5021) esp-tls: Failed to open new connection
E (5021) TRANS_SSL: Failed to open a new connection
E (5031) HTTP_CLIENT: Connection failed, sock < 0
E (5031) HTTP_CLIENT: Error perform http request ESP_ERR_HTTP_CONNECT
The configuration of the request that I am making is the following. Could you please help me? :)
  1. static void https_with_hostname_path(void)
  2. {
  3.     ESP_LOGI(TAG, "Test HTTPs skip CA");
  4.     esp_http_client_config_t config = {
  5.         .host = "www.howsmyssl.com",
  6.         .path = "/",
  7.         .transport_type = HTTP_TRANSPORT_OVER_SSL,
  8.         .event_handler = _http_event_handler,
  9.         .skip_cert_common_name_check = true
  10.     };
  11.     esp_http_client_handle_t client = esp_http_client_init(&config);
  12.     esp_err_t err = esp_http_client_perform(client);
  13.
  14.     if (err == ESP_OK) {
  15.         ESP_LOGI(TAG, "HTTPS Status = %d, content_length = %d",
  16.                 esp_http_client_get_status_code(client),
  17.                 esp_http_client_get_content_length(client));
  18.     } else {
  19.         ESP_LOGE(TAG, "Error perform http request %s", esp_err_to_name(err));
  20.     }
  21.     esp_http_client_cleanup(client);
  22. }
boarchuz
Re: skip server validation seems not to work
Postby boarchuz » Tue Jan 26, 2021 11:26 pm
skip_cert_common_name_check will not allow you to bypass TLS, it will only avoid checking the certificate's CN (so a possible mismatch would not fail validation).
To completely disable the certificate check, you will need to go to ESP-TLS in menuconfig, enable "Allow potentially insecure options" and then enable "Skip server certificate verification by default" (accepting risks)
jakarman12
Postby jakarman12 » Wed Jan 27, 2021 1:24 am
Hi @boarchuz,
Thanks for the answer, you are right there I was making a mistake due to a confusion that I was having between the CN and the CA.
I'm going to change the name of this post to serve as a tutorial for some clueless like me.
Again thank you very much. :D
prutek
Postby prutek » Sun Jul 11, 2021 9:39 pm
And you need to make changes in file "sdkconfig" in root directory of your project
it was really useful information for me because I spent an hour to find this file*
new in engineering, but really like it!
Users browsing this forum: Bing [Bot] and 98 guests
