Flashing ESP32
Nikosant03
Flashing ESP32
Postby Nikosant03 » Thu May 13, 2021 7:30 am
Hi everyone,
I want to intergrate the ESP32-S2-MINI module into my design. Can I use the JTAG interface for debugging and flashing as well? If JTAG serves both features do I need to include USB connector and USB to UART Bridge?
Nikosant03
Re: Flashing ESP32
Postby Nikosant03 » Mon May 24, 2021 8:19 am
Anyone?
PeterR
Re: Flashing ESP32
Postby PeterR » Mon May 24, 2021 4:25 pm
JTAG can be used to both program and debug:
https://www.esp32.com/viewtopic.php?t=7956
Well that is up to you.
JTAG is relatively expensive and not exactly consumer gear.
(1) you could use another style of connector, (2) reprogram over Wifi, (3) reprogram over USB, (4) have a programming dongle.
It depends on your use case.
Serial is cheap but for consumer reprogramming USB may be easiest.
If you go USB make sure your PSU can handle the card.
Users browsing this forum: No registered users and 304 guests
