ESP32 Pico Kit V4.1 hardware serial pins what numbers are they on the board?
knightridar
Contact:
Postby knightridar » Sun May 23, 2021 5:47 am
I've been trying to find them in the documentation.
The closest thing I could find was U1TXD and U1RXD (IO pins 10, 9)
Does a hardware code example exist somewhere of a hardware serial connection?
I've been trying to hook up a NEO 6M gps module via the serial ports just so I can get a read out on the PC.
Thanks.
esp32 pico kit v4.1 serial hardware pins.PNG (735.44 KiB) Viewed 4561 times
Free CAD files for hobby and engineering projects:
https://grabcad.com/has-2
Re: ESP32 Pico Kit V4.1 hardware serial pins what numbers are they on the board?
Postby ESP_Sprite » Mon May 24, 2021 1:39 am
In general, the ESP32 pins are highly configurable and I believe the Arduino environment allows you to specify which pins to use for Rx/Tx in software.
knightridar
Contact:
Postby knightridar » Sun May 30, 2021 8:57 am
But what if I want to use hardware serial are pins 9 and 10 good enough?
Right now all I get is zero display output.
Users browsing this forum: No registered users and 65 guests
