esp_log_level_set("wl_flash", ESP_LOG_VERBOSE); does not work
simonjo
Postby simonjo » Sat May 22, 2021 4:20 pm
Due to periodic corruption of my FATFS with Wear Leveling , I want to turn on some debug logging in the console.
Therefor I added esp_log_level_set("wl_flash", ESP_LOG_VERBOSE); as first statement in my code, but there is no debug output.
Even though my application writes to a logfile every minute.
Only after modifying sdkconfig to CONFIG_LOG_DEFAULT_LEVEL_VERBOSE does wl_flash debug appear, but not only wl_flash. Now a lot of other (unneeded) logging comes out.
Is this a bug or am I doing something wrong when using esp_log_level_set() ???
Thx, Jo
WiFive
Re: esp_log_level_set("wl_flash", ESP_LOG_VERBOSE); does not work
Postby WiFive » Sat May 22, 2021 7:15 pm
That's how it works. You have to set the default log level using wildcard then adjust individual levels.
https://github.com/espressif/esp-idf/bl ... pp#L88-L94
https://github.com/espressif/esp-idf/bl ... ig#L11-L15
There is also a new feature
https://github.com/espressif/esp-idf/bl ... config#L40
simonjo
Postby simonjo » Sat May 22, 2021 10:07 pm
Ok that explains it, compiled with LEVEL_VERBOSE and turned down obsolete loggings
thx
joy586210
Postby joy586210 » Tue Sep 26, 2023 2:46 pm
as explained here:
https://docs.espressif.com/projects/esp ... og_level_t
Note that this function can not raise log level above the level set using CONFIG_LOG_MAXIMUM_LEVEL setting in menuconfig.
Users browsing this forum: Baidu [Spider], Baldhead, Bing [Bot] and 136 guests
