How to disable secure boot V2 from esp32s2
ankayca
Postby ankayca » Sun May 09, 2021 1:05 pm
I activated secure boot v2 from :
https://docs.espressif.com/projects/esp ... re-boot-v2
I bought an esp prog to debug esp32s2. Openocd not working with secure boot so I want to disable secure boot.
I disabled from menuconfig but still when I try to flash program with this:
idf.py flash
(without port specification)
I got this
Executing action: flash
Serial port /dev/ttyUSB0
Connecting....
Detecting chip type...
/dev/ttyUSB0 failed to connect: Unsupported Command Error received. Probably this means Secure Download Mode is enabled, autodetection will not work. Need to manually specify the chip.
No serial ports found. Connect a device, or use '-p PORT' option to set a specific port.
Can someone know how secure boot will disable ?
ankayca
Re: How to disable secure boot V2 from esp32s2
Postby ankayca » Mon May 10, 2021 7:13 pm
Pump !
ESP_Angus
Postby ESP_Angus » Tue May 11, 2021 12:37 am
Hi ankayca,
I'm afraid that it's not possible to disable Secure Boot V2 once enabled. If it was, then this would provide a way to bypass Secure Boot protection.
It is possible to build a new bootloader and/or app, sign them with the key trusted by the device, and flash them.
This is a bug in idf.py when the target chip is in Secure Download Mode, the port detection doesn't work. We'll fix this, sorry for the inconvenience, but for a workaround you should be able to do "idf.py -p /dev/ttyUSB0 flash" instead.
(However, note that the new bootloader will fail to boot unless it's signed correctly for Secure Boot V2.)
Users browsing this forum: Bing [Bot], Google [Bot] and 81 guests
