/main.c:20:10: fatal error: esp_https_server.h: No such file or directory
eliott
Postby eliott » Thu Jan 14, 2021 6:33 pm
I'm trying to switch from and http server to https server.
I'm unable to compile in my program, but its the same in the example dir: \esp-idf\examples\protocols\https_server
Also If I want to check if my esp-idf is up to date I found this command "git pull origin master". I want to be sure that is the good command to executre in the "esp-idf" dir. This part is not specified in the documentation, does the new execution of "esp-idf-tools-setup-2.3" update the sdk ?
Thank you for help.
Eliott.
eliott
Re: /main.c:20:10: fatal error: esp_https_server.h: No such file or directory
Postby eliott » Mon Jan 25, 2021 7:58 pm
Solved: HTTPS component was not activated in sdkconfig (use idf.py menuconfig to set this option...)
kraxor
Postby kraxor » Tue Apr 27, 2021 10:17 am
Also don't forget you need to require it in CMakeLists.txt:
idf_component_register(
        SRCS
        REQUIRES
        "esp_https_server"
Users browsing this forum: Google [Bot] and 87 guests
