when use ESP-WROVER-KIT,always getting the message"Localhost:3333:Connection timed out."
I want to use ESP-WROVER-KIT to do JTAG debugging for ESP32,when I OpenOCD,run the command"xtensa-esp32-elf-gdb -ex 'target remote localhost:3333' ./build/app-template.elf",always getting the wrong mesagge"localhost:3333: Connection timed out."
What am I missing ? Maybe some access right ?
thanks for your help,
regards,
Alisa
regards,
Alisa
Re: when use ESP-WROVER-KIT,always getting the message"Localhost:3333:Connection timed out."
Are you sure the OpenOCD process is running when you run the gdb command? Can you copy/paste the output of openocd here?
Hi dear,
You are right,the OpenOCD process is not running,I run the OpenOCD commend"./src/openocd -s ./tcl -f ./esp.cfg" again,it show"Remote debugging using localhost:3333",but it may be has another question as below:
Ignoring packet error,continuing...
warning:unrecognized item "time out" in "qSupported" response
Bogus trace status reply from target:timeout
(gdb)
By the way,when I run the "./src/openocd -s ./tcl -f ./esp.cfg",the printing run all the time,It can't been halted even I press the reset button on the ESP-WROVER-KIT borad.
(gdb)
Hi dear,
After yesterday debugging,I get this wrong message as below:
0x00000000 in ?? ()
(gdb) b app_main
Breakpoint 1 at 0x401085f4:file app_main.c,line 35
(gdb)c
Continuing.
Warning:
Cannot insert breakpoint1.
Cannot access memory at address 0x401085f4
Is there something wrong for my operation ?
regards,
Alisa
0x00000000 in ?? ()
(gdb) b app_main
(gdb)c
Continuing.
Warning:
regards,
Alisa
Can you post the output of OpenOCD here? It almost seems like something else is listening on port 3333 on your machine...
Hi dear,
The output of OpenOCD as attachment,pls help to review,thanks~
- output of OpenOCD.doc
- (72 KiB) Downloaded 794 times
Hum. All I can see (and say) is that there's something going terribly wrong with the communication between the JTAG chip and the ESP32. Can you post a picture of the kit so I can see which jumpers are installed?
I have increased the base resistor on Q1 & Q2 - i think it was 10k i putted on...
/Rapzak
/Rapzak
Hi dear,
Pls review the esp-wrover-kit connection as attchment. To enable the JTAG function, I use shorting jumpers on JP8 (JTAG) for TMS、TDO、TDI、TCK、GND.
By the way,the GPIO12、GPIO13、GPIO14、GPIO15 can be reused?I may be use these GPIO to connect Camera.
- ESP-WROVER-KIT.jpg (3.46 MiB) Viewed 15912 times
Are you using GPIO12/13/14/15 right now? Because if that is the case, that is the reason your JTAG does not work: re-using the pins for different purposes is possible, but it will kill JTAG connectivity in weird and interesting ways and may lead to what you've seen.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot], ManX84 and 48 guests
