Maybe my question is trivial, but I need to start a project with the new ESP32-MINI-1 module and its ESP32-DevKitM-1 develop board. Until now I used the Arduino IDE for my projects with the ESP32-WROOM-32 without problem, but since the core of the new module (ESP32-U4WDH) seems to be different respect the WROOM (ESP32-D0WDQ6), I'm wondering if I'll have problems.
It's enough to keep the 'ESP32 Dev Module' selected in the board setting of the IDE?
Anyone have some suggestions or usefull infos?
Will the new ESP32-MINI-1 module be supported?
Re: Will the new ESP32-MINI-1 module be supported?
The change in markings is a package change: the one in the MINI-1 (off the top of my head) is smaller and has flash integrated. Software-wise, there should be no difference, the ESP32 die is still the same.
ESP_Sprite wrote: ↑Sat Apr 03, 2021 1:10 pmThe change in markings is a package change: the one in the MINI-1 (off the top of my head) is smaller and has flash integrated. Software-wise, there should be no difference, the ESP32 die is still the same.
So you can confirm me that if I chose 'ESP32 Dev Module' in the board setting of Arduino IDE I won't have problem with this new module and its develop board? I will still use the same libraries (for example, I'm interested to the BLE ones as BLEDevice.h, BLEUtils.h, BLEServer.h) that I've used in the past with the ESP32-WROOM-32?
I can't confirm it as I have not tested it. I can only say that you should be able to use the same settings. (Now that I think about it, actually, some GPIO settings may be different. Check the datasheet to be sure.)
I have an ESP32-MINI-1 module on a custom design and after some struggles I am able to program it using ESP32 Arduino, but there appears to be a problem.
The boot UART log throws this error:
The arduino IDE seems to be compiling for a dual core ESP32 and some other problems, whereas the mini module uses a single core one. I'm currently using the ESP32 Dev Module option as the board, is there a better one to use for this single core chip?
ets Jul 29 2019 12:21:46
configsip: 188777542, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
E (215) cpu_start: Running on single core chip, but application is built with dual core support.
E (215) cpu_start: Please enable CONFIG_FREERTOS_UNICORE option in menuconfig.
abort() was called at PC 0x4008476d on core 0
ELF file SHA256: 0000000000000000
Backtrace: 0x40088504:0x3ffe3be0 0x40088781:0x3ffe3c00 0x4008476d:0x3ffe3c20 0x4007925f:0x3ffe3c40 0x400792c5:0x3ffe3c70 0x400792d0:0x3ffe3ca0 0x4007947d:0x3ffe3cc0 0x400806e6:0x3ffe3df0 0x40007c15:0x3ffe3eb0 0x4000073d:0x3ffe3f20
Rebooting...
Thank you! I was able to find the previous files in directories under "C:\Users\[Username]\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6" on my windows machine.
Is this support planned to be added to ESP32-Arduino in the future? If not, I would recommend adding an "expected locations" to the readme to simplify installation.
Users browsing this forum: No registered users and 47 guests
