I (322) cpu_start: Starting scheduler on PRO CPU.
I (727) tsens: Config temperature range [-10°C ~ 80°C], error < 1°C
abort() was called at PC 0x40024263 on core 0
0x40024263: lock_acquire_generic at /Users/ss/Documents/dev/esp/esp-idf/components/newlib/locks.c:138
Backtrace:0x40027783:0x3ffc34c0 0x4002802d:0x3ffc34e0 0x4002ceaa:0x3ffc3500 0x40024263:0x3ffc3570 0x400243ad:0x3ffc35a0 0x4001a245:0x3ffc35c0 0x40000baa:0x3ffc35e0 0x40000a65:0x3ffc3690 0x4001a428:0x3ffc36e0 0x4002c0b3:0x3ffc3710 0x4002cbe3:0x3ffc3730 0x4002357d:0x3ffc3750 0x400235ad:0x3ffc3770 0x4002ceb5:0x3ffc3790 0x4008564d:0x3ffc37b0 0x40085532:0x3ffc37d0 0x40085466:0x3ffc37f0 0x40097a62:0x3ffc3810 0x4002a289:0x3ffc3830
0x40027783: panic_abort at /Users/ss/Documents/dev/esp/esp-idf/components/esp_system/panic.c:354
0x4002802d: esp_system_abort at /Users/ss/Documents/dev/esp/esp-idf/components/esp_system/system_api.c:112
0x4002ceaa: abort at /Users/ss/Documents/dev/esp/esp-idf/components/newlib/abort.c:46
0x400243ad: _lock_acquire_recursive at /Users/ss/Documents/dev/esp/esp-idf/components/newlib/locks.c:166
0x4002c0b3: block_locate_free at /Users/ss/Documents/dev/esp/esp-idf/components/heap/heap_tlsf.c:447
(inlined by) tlsf_malloc at /Users/ss/Documents/dev/esp/esp-idf/components/heap/heap_tlsf.c:757
0x4002cbe3: multi_heap_malloc_impl at /Users/ss/Documents/dev/esp/esp-idf/components/heap/multi_heap.c:197
0x4002357d: heap_caps_malloc at /Users/ss/Documents/dev/esp/esp-idf/components/heap/heap_caps.c:145
0x400235ad: heap_caps_malloc_default at /Users/ss/Documents/dev/esp/esp-idf/components/heap/heap_caps.c:177
0x4002ceb5: malloc at /Users/ss/Documents/dev/esp/esp-idf/components/newlib/heap.c:31
0x4008564d: hu_de_ba_es_init at /Users/ss/Documents/dev/embedded/the_proj/components/hu_de/src/hu_de_ba_est.c:20
0x40085532: hu_de_init at /Users/ss/Documents/dev/embedded/the_proj/components/hu_de/src/hu_de.c:23
0x40085466: app_main at /Users/ss/Documents/dev/embedded/the_proj/hu_de_pg/build/../main/hu_de_pg.c:70
0x40097a62: main_task at /Users/ss/Documents/dev/esp/esp-idf/components/freertos/port/port_common.c:134
0x4002a289: vPortTaskWrapper at /Users/ss/Documents/dev/esp/esp-idf/components/freertos/port/xtensa/port.c:168
When I open that file and navigate to line 138, I see the following comment:
/* In ISR Context */
if (mutex_type == queueQUEUE_TYPE_RECURSIVE_MUTEX) {
abort(); /* recursive mutexes make no sense in ISR context */
P = malloc(n_pixels * sizeof(float));
if (P == NULL) {
res = ESP_ERR_NO_MEM;
goto cleanup;
for (i = 0; i < n_pixels; i++) {
P[i] = P_INIT;
X = malloc(2 * n_pixels * sizeof(float));
if (X == NULL) {
goto cleanup;
for (i = 0; i < n_pixels * 2; i++) {
X[i] = t_init;
X[i + 1] = td_init;
A = malloc(4 * sizeof(float));
if (A == NULL) {
goto cleanup;
A[0] = 1; A[1] = 1; A[2] = 0; A[3] = 1;
Any help is greatly appreciated. Thanks!
