REUSEPORT FAIL / LINGER FAIL errors, while connecting to tcp server
Alehandro
Postby Alehandro » Tue Apr 06, 2021 8:17 am
Hi everyone!
I used ESP8285 in my design. From the datasheet I got that UART pins are GPIO1/3. But i didnt notice that AT-commands pins are GPIO13/15. Actualy there is no word in the datasheet about it. And we've already ordered 200 pcbs, but i pulled GPIO15 hard to the gnd under qfn package 8285.
I recompilled firmware. And as it is said here https://docs.espressif.com/projects/esp ... t_pin.html I changed UART pins to GPIO3/1. And everything works fine. But when I connect to my Server, ESP throws this errors:
AT+CIPSTART="TCP","<ip>",23341
REUSEPORT FAIL
LINGER FAIL
CONNECT
OK
But everything works fine! Connecting/disconnecting, sending data..
Does anyone know what the errors are: REUSEPORT FAIL, LINGER FAIL? and why does esp work despite errors?
This is a commercial project, so, although it works, it is scary to send it to release with some errors ..
Start info from chip:
phy_version: 1163.0, 665d56c, Jun 24 2020, 10:00:08, RTOS new
module_name:WROOM-02
max tx power=78,ret=0
2.0.0
ready
AT+GMR
AT version:2.2.0.0-dev(875d40c - ESP8266 - Mar 31 2021 03:50:00)
SDK version:v3.4-rc
compile time(4920382):Apr  5 2021 18:02:09
Bin version:2.0.0(WROOM-02)
OK
Also, I downloaded my firmware to module WROOM-02 - the errors are the same and everything works the same.
ESP_Minatel
Re: REUSEPORT FAIL / LINGER FAIL errors, while connecting to tcp server
Postby ESP_Minatel » Tue Apr 06, 2021 8:42 am
You should try posting on the ESP8266 Forum to get someone help from there.
Alehandro
Postby Alehandro » Tue Apr 06, 2021 9:35 am
Sorry.
Asked there.
Please close this topic.
Users browsing this forum: No registered users and 87 guests
