i power on esp32, (GPOI 0 is 10k pull up)
and flash hello-world example (with FLASH_DOWNLOAD_TOOLS_V3.4.4)
but it is reset repearedly with this message
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0x00
mode:DIO, clock div:2
load:0x3ffc0008,len:0
load:0xffffffff,len:-1
how i can fix this problem
esp32 reset repeatedly
Re: esp32 reset repeatedly
What hardware do you have? Can you also try flashing using 'make flash'?
i use customized esp32 module but it is same to esp32 demo board v2,ESP_Sprite wrote:What hardware do you have? Can you also try flashing using 'make flash'?
and make flash in msys2_shell
but same error message
So it's customized, right? What is the difference between it and the v2 demo board? Also, what are you using as a 3.3V power supply?
Also, could you please try to select DOUT flash mode instead of DIO (in menuconfig, serial flasher options)?
From the log it appears that the ROM bootloader is not reading valid data from flash.
Users browsing this forum: Bing [Bot] and 312 guests
