When might the stepper example for the a4988 driver be re-released? Or is it permanently withdrawn?
There are references to it last year but these give a 404 and "This page does not exist yet." respectively.
Are there any other stepper examples?
https://github.com/espressif/esp-iot-so ... /a4988.cpp
https://esp-iot.readthedocs.io/en/lates ... pper/a4988
a4988 Stepper Code Release
Re: a4988 Stepper Code Release
Seems that code got removed from the v2.0 release of that library. You can always switch to the release/v1.1 branch to see what's there: link. Note that there probably is a reason the devs removed it, and you may need to massage the code a bit to work in current esp-idf versions.
Thanks.
From the top of https://github.com/espressif/esp-iot-so ... 4438c87d25 is the statement
" revert(motor/stepper): temporarily remove stepper, you can refer release/1.0 for test"
which suggested that a release was due soon.
However, running
git clone --recursive https://github.com/espressif/esp-iot-solution
4988 or stepper is absent and the only item under "motor" is servo.
Who in Espressif should I ask to ascertain the planned release date or confirmation of permanent withdrawal?
Regards
However, running
Regards
