Wake-up stub DPORT access not working
bittnert
Postby bittnert » Thu Mar 11, 2021 8:01 pm
I try to work with I2C within a wake up stub on my esp32. To this end I wrote a function to initialize I2C and a function to send something.
These functions only use macros and are placed in RTC fast memory. I tested these function with the main CPU (within the RTOS) and it works fine. When I tried to call the within the wake up stub the watchdog triggered a system reset.
I thought the I2C communication take to much time so I deactivated the watchdog within the wake-up stub to realize that the initialization function stops execution.
The function is shown below.
void RTC_IRAM_ATTR stub_init_i2c(uint32_t scl_pin, uint32_t sda_pin)
     /* GPIO Settings */
     REG_SET_BIT(GPIO_OUT_W1TS_REG, (1 << scl_pin));
     REG_SET_BIT(GPIO_OUT_W1TS_REG, (1 << sda_pin));
     PIN_FUNC_SELECT(GPIO_PIN_MUX_REG[scl_pin], PIN_FUNC_GPIO);
     PIN_FUNC_SELECT(GPIO_PIN_MUX_REG[sda_pin], PIN_FUNC_GPIO);
     REG_SET_BIT(GPIO_PIN_MUX_REG[scl_pin], FUN_IE);
     REG_SET_BIT(GPIO_PIN_MUX_REG[sda_pin], FUN_IE);
     REG_SET_BIT(GPIO_ENABLE_W1TS_REG, (1 << scl_pin));
     REG_SET_BIT(GPIO_ENABLE_W1TS_REG, (1 << sda_pin));
     STUB_GPIO_PIN_REG(scl_pin) |= (1 << 2);
     STUB_GPIO_PIN_REG(sda_pin) |= (1 << 2);
     REG_SET_BIT(GPIO_PIN_MUX_REG[scl_pin], (1 << 8));
     REG_SET_BIT(GPIO_PIN_MUX_REG[sda_pin], (1 << 8));
     REG_CLR_BIT(GPIO_PIN_MUX_REG[scl_pin], (1 << 7));
     REG_CLR_BIT(GPIO_PIN_MUX_REG[sda_pin], (1 << 7));
     STUB_GPIO_FUNC_OUT_SEL_REG(sda_pin) = 30;
     STUB_GPIO_FUNC_OUT_SEL_REG(scl_pin) = 29;
     STUB_GPIO_FUNC_IN_SEL_REG(30) = sda_pin;
     STUB_GPIO_FUNC_IN_SEL_REG(29) = scl_pin;
      /*DPORT Settings (Clock and reset) */
     /* Activate I2C0 */
     DPORT_REG_CLR_BIT(DPORT_PERIP_RST_EN_REG, (1 << 7)); <<== This call stops execution
#if 0
     /* Activate I2C0 Clock */
     DPORT_REG_SET_BIT(DPORT_PERIP_CLK_EN_REG, (1 << 7));
     /* I2C Settings */
     uint32_t half_cycles = 400;
     REG_WRITE(I2C_SCL_LOW_PERIOD_REG(0), half_cycles);
     REG_WRITE(I2C_SCL_HIGH_PERIOD_REG(0), half_cycles);
     REG_WRITE(I2C_SDA_HOLD_REG(0),half_cycles/2);
     REG_WRITE(I2C_SDA_SAMPLE_REG(0), half_cycles/2);
     REG_WRITE(I2C_SCL_START_HOLD_REG(0), half_cycles);
     REG_WRITE(I2C_SCL_RSTART_SETUP_REG(0), half_cycles);
     REG_WRITE(I2C_SCL_STOP_SETUP_REG(0), half_cycles);
     REG_WRITE(I2C_SCL_STOP_HOLD_REG(0),half_cycles);
     REG_WRITE(I2C_TO_REG(0), half_cycles*20);
     /* Enable master mode*/
     REG_WRITE(I2C_CTR_REG(0), 19);
     /* Enable I2C_NONFIFO_EN as stated in technical reference manual*/
     REG_WRITE(I2C_TO_REG(0), 8000);
     REG_WRITE(I2C_SCL_FILTER_CFG_REG(0), 17);
     REG_WRITE(I2C_SDA_FILTER_CFG_REG(0), 17);
 #endif
After further investigation, I found out that reading DPORT registers (which I need to do to activate the I2C core).
As the memory mapped access to DPORT hangs, it seems to me DPORT has to be initialized before accessing it. Unfortunately reading the eps32 technical reference manual did not reveal what I have to do before accessing the DPORT registers.
Does anyone have any idea why this access is not working?
Thank you very much.
BR
Thomas
bittnert
Re: Wake-up stub DPORT access not working
Postby bittnert » Fri Mar 12, 2021 9:41 pm
Thank you very much. Changing the macro to the _DPORT_REG_CLR_BIT does not get stuck anymore. Unfortunately, the sending using I2C still does not work. I will have to debug this.
Users browsing this forum: No registered users and 83 guests
