I was wondering if anyone can tell me , what is preloaded on the esp32 wroom 32 at the first boot.
I have seen that on the first boot ESP32 create an access point with the name "ESP_XXXX". The AP is open, you can connect and you receive a valid IP and configuration , but this is all. If i connect the 192.168.4.1 i get connection refused. So what is the meaning of this AP? can be used To perform an OTA. Please Help i am confused, btw removing the need of a first serial programming is very interesting.
First boot Access Point
Re: First boot Access Point
This depends a lot. If you have an Espressif module from the factory, then you have no firmware pre-loaded. This could be customized in large quantities, but you need to contact sales directly for a more detailed answer.
But you have many different vendors that ship their development boards with a pre-loaded firmware. Sometimes there is pre-loaded firmware but just for factoring testing purpose or with a demo firmware to show some capabilities/feature.
Thank you for this answer, the module i have tried wroom 32D and wroom 32E standalone modules bought from Mouser and Digikey. Maybe this info can clarify. So , if i understand correctly , there is no way to flash the first firmware by wifi, i always need a programmer?
I think there isin't any option to do it by wifi
Content creator at https://911electronic.com
Users browsing this forum: Google [Bot] and 101 guests
