Blutooth example.
Blutooth example.
Hello.
I need to connect two ESP32 devices via blutooth and I am looking for a working example of this task. One device will send data, the other will receive and do something. I know there have been many projects like this, but I'm a beginner and haven't found a single example. Can you help me with this, pls?
My best regards,
User4356.
My best regards,
User4356.
Re: Blutooth example.
You can try the GATT Client and Server examples on our GitHub.
GATT Client
GATT Server
Hope this could help you!
GATT Client
GATT Server
Thank you for answer.
Now I'm studying the bluetooth specification and found out that there are two versions: Bluetooth Classic and Bluetooth Low Energy. I have no experience at all, but the task that I want to implement is to transmit audio over a wireless. Do I understand correctly that I need a classic bluetooth? Which of these specifications is implemented in your example?
I just noticed that this is not just an example, this is a whole tutorial! This can be very, very helpful. Thank you very much again. But in the description, the example uses the Blutooth Low Energy version, and I need sound transmission. Tell me, is there a similar tutorial for classic bluetooth? Or maybe there is an opportunity in a simple way to convert it to the Bluetooth Classic standart? Or maybe I can implement my task on Blutooth Low Energy?
I suggest you to use BLE instead of Classic.
We also provide you a development framework for audio: ESP-ADF
Thank you for response!
Now I am reading documentation and I found an inaccuracy.
In: https://github.com/espressif/esp-idf/bl ... cteristics
In paragraph:
Correct me, I am wrong.
In paragraph:
Sentence:"First, the service handle generated by the BLE stack is stored in the profile table, which will be used later by the application layer to refer to this service. Then, the UUID of the characteristic and its UUID length are set. The length of the characteristic UUID is again 16 bits. The service is started using the esp_ble_gatts_start_service() function with the service handle previously generated. An ESP_GATTS_START_EVT event, which is used to print information, is triggered. The characteristic is added to the service by the esp_ble_gatts_start_service() function in conjunction with the characteristics permissions and properties. In this example, the characteristics in both profiles are set up as follows:"
seems not a true. As I understand code, characteristic added by that function:"The characteristic is added to the service by the esp_ble_gatts_start_service() function"
esp_err_t add_char_ret = esp_ble_gatts_add_char(gl_profile_tab[PROFILE_A_APP_ID].service_handle, &gl_profile_tab[PROFILE_A_APP_ID].char_uuid,
ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
a_property,
&gatts_demo_char1_val, NULL);
Thank you for reporting! We will check and review this information.
I finished server tutorial, but there is some code not explained. Can you tell me, what this code do?
case ESP_GATTS_WRITE_EVT: {
ESP_LOGI(GATTS_TAG, "GATT_WRITE_EVT, conn_id %d, trans_id %d, handle %d", param->write.conn_id, param->write.trans_id, param->write.handle);
if (!param->write.is_prep){
ESP_LOGI(GATTS_TAG, "GATT_WRITE_EVT, value len %d, value :", param->write.len);
esp_log_buffer_hex(GATTS_TAG, param->write.value, param->write.len);
if (gl_profile_tab[PROFILE_A_APP_ID].descr_handle == param->write.handle && param->write.len == 2){
uint16_t descr_value = param->write.value[1]<<8 | param->write.value[0];
if (descr_value == 0x0001){
if (a_property & ESP_GATT_CHAR_PROP_BIT_NOTIFY){
ESP_LOGI(GATTS_TAG, "notify enable");
uint8_t notify_data[15];
for (int i = 0; i < sizeof(notify_data); ++i)
notify_data[i] = i%0xff;
//the size of notify_data[] need less than MTU size
esp_ble_gatts_send_indicate(gatts_if, param->write.conn_id, gl_profile_tab[PROFILE_A_APP_ID].char_handle,
sizeof(notify_data), notify_data, false);
}else if (descr_value == 0x0002){
if (a_property & ESP_GATT_CHAR_PROP_BIT_INDICATE){
ESP_LOGI(GATTS_TAG, "indicate enable");
uint8_t indicate_data[15];
for (int i = 0; i < sizeof(indicate_data); ++i)
indicate_data[i] = i%0xff;
//the size of indicate_data[] need less than MTU size
sizeof(indicate_data), indicate_data, true);
else if (descr_value == 0x0000){
ESP_LOGI(GATTS_TAG, "notify/indicate disable ");
}else{
ESP_LOGE(GATTS_TAG, "unknown descr value");
example_write_event_env(gatts_if, &a_prepare_write_env, param);
break;
There is something else I dont undestand.
Here: https://github.com/espressif/esp-idf/bl ... g-services
Why there is no esp_ble_gatts_create_attr_tab() function in example of gatt server?
https://github.com/espressif/esp-idf/bl ... tts_demo.c
First it is talking about esp_ble_gatts_create_attr_tab() function, but there is no that function in example code. In example code is esp_ble_gatts_create_service() function. So, how to use esp_ble_gatts_create_attr_tab and when?The register event is also used to create a profile attributes table by using the esp_ble_gatts_create_attr_tab() function, which takes an esp_gatts_attr_db_t type structure that has all the information of the service table. The way to create this table is:
… esp_ble_gatts_create_service(gatts_if, &gl_profile_tab[PROFILE_A_APP_ID].service_id, GATTS_NUM_HANDLE_TEST_A); break; …
Another one misunderstanding in tutorials.
https://github.com/espressif/esp-idf/bl ... through.md
(I hope somebody read that topic)
Just read the second sentence. Besides the fact that the same function is repeated twice, it is also not correct. Correct function is: gattc_profile_event_handler().The initialization of the Application Profile table array includes defining the callback functions for each Profile. These are gattc_profile_a_event_handler() and gattc_profile_a_event_handler() respectively. In addition, the GATT interface is initialized to the default value of ESP_GATT_IF_NONE. Later on, when the Application Profile is registered, the BLE stack returns a GATT interface instance to use with that Application Profile.
Users browsing this forum: Google [Bot] and 109 guests
