Bluetooth HID Host Getting Duplicate Events and Extra Event
Derf Jagged
Postby Derf Jagged » Sun Jan 03, 2021 11:42 pm
Hello! I have connected my Xbox One S controller to the ESP32 via Bluetooth and can see and parse button press and release events. However, it looks like every time I press a button on the controller, it fires three events instead of just one, and occasionally one of the three events is completely different data. Any idea why it's firing three events and what the other data is? Is there any easy way to ignore the last two events?
The picture below shows me pressing a button five times, which changes one value from 00 to 05. In between the second button release and the third button press, it has a bad data event.
And here's a picture with the ESP_HIDH_DEMO's default logging and a couple bad events. This shows it's from the same MAC and same event ID (1).
Finally, here's my connected device info:
Thanks for reading!
Derf Jagged
Re: Bluetooth HID Host Getting Duplicate Events and Extra Event
Postby Derf Jagged » Fri Jan 08, 2021 2:49 am
Still haven't found a solution for this.
ESP_Jan
Postby ESP_Jan » Thu Jan 14, 2021 5:09 pm
Hi Derf Jagged,
the extra packets may be controller status information (like the state of charge, firmware version, signal strength, etc.)
I wasn't able to find much information on the Bluetooth protocol, but this page has information about the proprietary wireless communication protocol https://gist.github.com/devkid/4b3bd507 ... 4cfd3ed895
There's also an open-source Linux driver for the Bluetooth controller: https://github.com/atar-axis/xpadneo
Jan
Derf Jagged
Postby Derf Jagged » Thu Jan 14, 2021 8:13 pm
Thanks for the reply.
Looking through the pages you linked (and some pages linked there), the regular wireless protocol is a bit different from the Bluetooth one; the Bluetooth one doesn't have a counter for instance and the duplicate events may be Bluetooth only.
The esp_hid_host sample filters out anything that is not an ESP_HIDH_INPUT_EVENT (value 02), I believe this is the same value in the page you linked (https://gist.github.com/devkid/4b3bd507 ... 4cfd3ed895) that they use for filtering everything but packets with the command / status flag set to (20 00) which seems to be button inputs. It appears that the "junk" data values I'm getting are also mmarked as ESP_HIDH_INPUT_EVENT's with value (20 00) for some reason, as the controller firmware status information are filtered out properly.
I did just notice that there actually is a consistent difference between regular events and the junk events, and that's a "fd 3f" value in the middle. Here's a handful of junk events, it looks like sometimes they repeat and sometimes not:
37 97 f7 fd 3f 94 f7 fd 3f 00 00 00 00 00 00
3f 3c ca fd 3f c4 a9 fd 3f 00 11 19 00 01 00
00 00 00 ff 4e d1 a9 fd 3f 88 ab fd 3f 0c 3b
00 00 00 d9 4e e0 aa fd 3f 00 11 19 00 01 00
2b 81 c9 fd 3f d4 c9 fd 3f 49 47 48 54 20 00
29 95 89 fd 3f b4 8b fd 3f 49 47 48 54 20 00
00 00 00 00 00 3c ab fd 3f 01 00 00 00 41 00
3f 74 cb fd 3f 1c aa fd 3f fc ab fd 3f 38 3f
I can at least filter on that value, but it is possible that someone holds down the analog stick and trigger to the exact positions that it would drop inputs... so figuring out the root cause would be better.
Users browsing this forum: Majestic-12 [Bot] and 67 guests
