About the CAN controller.
Re: About the CAN controller.
Rudi: That would be the choice of the author of that driver. If he wants, he can file a pull request in the esp-idf github and we'll check the code quality and such and if that's OK, we will integrate it into esp-idf. If he prefers to have the driver as a separate component, that is fine too.
sry for confusion,Hans Dorn wrote:I know the theoretical throughput
At 1MBit you should be able to push out a little less than 8000 frames per second.
Did you really see 20 - 50 ms between frames, or are these µs?
Still a lot, considering a fast frame is only a bit more than 100µs...
Cheers
Hans
here in a test, that i can see the messages on receiver side with printf,
i have a delay in code between next send, sure you can have lees value of delay in the "house-can-bus or openCAN end firmware :
void task_CAN_TX(void* pvParameters) {
CAN_frame_t __TX_frame;
uint32_t counter = 0;
__TX_frame.MsgID = 0x264;
__TX_frame.DLC = 8;
__TX_frame.data.u8[0] = 'E';
__TX_frame.data.u8[1] = 'S';
__TX_frame.data.u8[2] = 'P';
__TX_frame.data.u8[3] = '-';
__TX_frame.data.u8[4] = 'C';
__TX_frame.data.u8[5] = 'A';
__TX_frame.data.u8[6] = 'N';
__TX_frame.data.u8[7] = counter;
while(1) {
CAN_write_frame(&__TX_frame);
vTaskDelay( 50 / portTICK_PERIOD_MS); // to see ( printf on receiver side ) what happend..
counter++;
if (counter >= 256) counter = 0;
rudi
no problem with the author jeroen, he did pleased me too comments and make it ready for the structure of ESP-IDF as driver so that we can add according to guidelines. with little changes and menuconfig gaves the CAN Driver at last the finnish and is now ready,ESP_Sprite wrote:Rudi: That would be the choice of the author of that driver. If he wants, he can file a pull request in the esp-idf github and we'll check the code quality and such and if that's OK, we will integrate it into esp-idf. If he prefers to have the driver as a separate component, that is fine too.
as Driver in ESP-IDF or/and third party and a example code is ready too.
i do next time create a repo for this, upload it for people how wants use it yet with menuconfig,
i do then make a PR to the author repo as "third party", then the author can make a PR to ESP-IDF repo or "third party"
why this a little confuse is, the author willl have no access to a computer for the next weeks....nothing creepy
and i can not add Contributor License Agreement things in order of espressif.. cause have not the legal capacity to create contracts in Espressifs name.
so the author then can confirm later itself Contributor License Agreement if he makes the PR.
rudi
Hi there,
I tried to compile the previously named CAN example
I get an error like this:
/ESP32-CAN/main///main.c:102:1: fatal error: opening dependency file //main.d: Permission denied
Is there further configuration of the source file needed?
Best regards
DL88AI88
Best regards
DL88AI88
hiDL88AI88 wrote: I get an error like this:
if you work in a VM which os you use as host and which os you use as gast?
if you in a OS, in which os you work?
rudi
$ make -j5 all
Building partitions from /c/idf/2114/components/partition_table/partitions_singleapp.csv...
CC bt.o
CC esp_ota_ops.o
CC src/bootloader_random.o
CC libcoap/src/address.o
AR libbt.a
CC src/flash_encrypt.o
CC libcoap/src/async.o
CXX cxx_guards.o
AR libapp_update.a
CC src/esp_image_format.o
CC rtc_module.o
CC src/flash_partitions.o
CC libcoap/src/block.o
CC src/secure_boot_signatures.o
CC i2c.o
CC libcoap/src/coap_time.o
CC src/secure_boot.o
CC src/efuse.o
CC libcoap/src/debug.o
CC src/bootloader_flash.o
CC sdmmc_host.o
AR libbootloader_support.a
CC libcoap/src/encode.o
AR libcxx.a
CC timer.o
CC int_wdt.o
CC libcoap/src/hashkey.o
CC libcoap/src/mem.o
CC brownout.o
CC emac_main.o
CC sdmmc_transaction.o
CC system_api.o
CC libcoap/src/net.o
CC rmt.o
CC hw_random.o
CC emac_dev.o
CC cpu_freq.o
AR libethernet.a
CC pcnt.o
CC libcoap/src/option.o
CC event_loop.o
CC core_dump.o
CC libcoap/src/pdu.o
CC src/efuse.o
CC gpio.o
CC library/xmltok_impl.o
CC intr_alloc.o
CC libcoap/src/resource.o
CC library/xmlrole.o
CC ledc.o
CC ipc.o
CC libcoap/src/str.o
CC library/xmlparse.o
CC log.o
CC freertos_hooks.o
CC libcoap/src/subscribe.o
CC periph_ctrl.o
CC heap_alloc_caps.o
AR liblog.a
CC libcoap/src/uri.o
CC i2s.o
CC deep_sleep.o
CC port/coap_io_socket.o
CC uart.o
CC phy_init.o
CC library/xmltok.o
CC spi_flash_rom_patch.o
CC crosscore_int.o
AR libcoap.a
AR libspi_flash.a
CC sigmadelta.o
CC cpu_util.o
CC spi_master.o
CC gdbstub.o
CC micro-ecc/uECC.o
CC lib_printf.o
CC cpu_start.o
CC src/option/unicode.o
AR libdriver.a
CC library/xmltok_ns.o
AR libmicro-ecc.a
CC src/option/syscall.o
CC task_wdt.o
CC port/chardata.o
CC xtensa_overlay_os_hook.o
CC flash_qio_mode.o
CC src/diskio.o
CC event_default_handlers.o
CC FreeRTOS-openocd.o
CC port/expat_element.o
CC bootloader_start.o
CC src/vfs_fat.o
CC timers.o
CC port/minicheck.o
CC panic.o
CC tasks.o
AR libmain.a
CC src/vfs_fat_sdmmc.o
AR libexpat.a
CC hwcrypto/aes.o
CC hwcrypto/sha.o
CC src//jsmn.o
CC src/ff.o
LD bootloader.elf
CC event_groups.o
AR libjsmn.a
AR libesp32.a
CC heap_regions.o
CC log.o
AR libfatfs.a
CC library/cJSON.o
AR liblog.a
CC port.o
esptool.py v2.0-beta2
CC xtensa_init.o
CC mdns.o
CC port/cJSON_Utils.o
CC list.o
CC apps/dhcpserver.o
CC croutine.o
AR libjson.a
CC queue.o
CC micro-ecc/uECC.o
CC library/havege.o
CC xtensa_intr.o
CC heap_regions_debug.o
AR libmicro-ecc.a
AR libmdns.a
CC library/ssl_cookie.o
CC core/tcp_out.o
CC ringbuf.o
CC locks.o
CC syscall_table.o
CC core/udp.o
AS portasm.o
CC library/md5.o
AS xtensa_vectors.o
CC syscalls.o
CC core/def.o
CC library/nghttp2_map.o
CC library/certs.o
CC reent_init.o
AS xtensa_context.o
CC core/timers.o
CC time.o
CC library/ssl_ciphersuites.o
CC library/nghttp2_submit.o
AS xtensa_intr_asm.o
AR libfreertos.a
CC library/camellia.o
AR libnewlib.a
CC core/stats.o
CXX src/nvs_api.o
CC core/netif.o
CC library/x509_crl.o
CC library/nghttp2_queue.o
CC library/ssl_stack.o
CC core/pbuf.o
CC library/nghttp2_pq.o
CC library/threading.o
CC library/aesni.o
CC library/nghttp2_hd_huffman_data.o
CC library/ssl_lib.o
CC library/bignum.o
CC core/tcp_in.o
CC library/nghttp2_outbound_item.o
CC library/ssl_x509.o
CC library/arc4.o
CC library/nghttp2_frame.o
CC core/raw.o
CC library/ssl_pkey.o
CC library/cipher_wrap.o
CC core/ip.o
CC library/ssl_methods.o
CC library/nghttp2_helper.o
CXX src/nvs_storage.o
CC library/aes.o
CC core/dns.o
CC library/ssl_cert.o
CC library/nghttp2_npn.o
CC library/xtea.o
CC platform/ssl_port.o
CC library/nghttp2_option.o
CC core/tcp.o
CC library/base64.o
CC platform/ssl_pm.o
CC library/nghttp2_buf.o
CC core/sys.o
CC library/sha512.o
CC library/pkcs11.o
CC library/nghttp2_priority_spec.o
CC core/memp.o
AR libopenssl.a
CC library/asn1write.o
CC library/nghttp2_hd.o
CXX src/nvs_pagemanager.o
CC sdmmc_cmd.o
CC core/init.o
CC library/oid.o
AR libsdmmc.a
CC core/inet_chksum.o
CC library/ecjpake.o
CC library/nghttp2_stream.o
CC core/mem.o
CC library/ssl_tls.o
CXX src/nvs_item_hash_list.o
CC library/nghttp2_session.o
CC api/lwip_debug.o
CC api/sockets.o
CXX src/nvs_page.o
CC flash_ops.o
CC library/debug.o
CC library/net.o
CC library/ecdh.o
CC api/api_msg.o
CXX src/nvs_types.o
CC library/nghttp2_callbacks.o
CC cache_utils.o
CC library/x509_crt.o
CC library/nghttp2_rcbuf.o
CC api/err.o
CC library/nghttp2_hd_huffman.o
AR libnvs_flash.a
CC api/netbuf.o
CC library/ssl_srv.o
CC partition.o
CC tcpip_adapter_lwip.o
CC library/nghttp2_mem.o
CC api/tcpip.o
CC library/nghttp2_version.o
CC flash_mmap.o
CC api/netifapi.o
AR libtcpip_adapter.a
CC library/ecdsa.o
CC library/nghttp2_http.o
CC api/api_lib.o
AR libspi_flash.a
CC library/md2.o
CC port/http_parser.o
CC ulp.o
CC vfs.o
CC library/x509_create.o
CC api/netdb.o
CC vfs_uart.o
AR libulp.a
CC library/memory_buffer_alloc.o
AR libvfs.a
CC api/pppapi.o
CC library/gcm.o
CC apps/sntp/sntp.o
AR libnghttp.a
CC trax.o
CC library/version.o
CC src/crypto/ms_funcs.o
CC eri.o
CC apps/ping/esp_ping.o
CC library/pem.o
AR libxtensa-debug-module.a
CC apps/ping/ping.o
CC src/crypto/crypto_internal-cipher.o
CC library/padlock.o
CC core/ipv4/icmp.o
CC library/asn1parse.o
CC src/crypto/crypto_internal-modexp.o
CC core/ipv4/autoip.o
CC library/timing.o
CC src/crypto/bignum.o
CC core/ipv4/ip4.o
CC library/ssl_cli.o
CC library/pkwrite.o
CC core/ipv4/igmp.o
CC src/crypto/sha1-pbkdf2.o
CC core/ipv4/ip4_addr.o
CC library/ssl_cache.o
CC src/crypto/aes-cbc.o
CC core/ipv4/dhcp.o
CC library/sha256.o
CC src/crypto/md5.o
CC library/md_wrap.o
CC core/ipv4/ip_frag.o
CC src/crypto/rc4.o
CC core/ipv6/icmp6.o
CC library/entropy.o
CC src/crypto/sha256.o
CC core/ipv6/ethip6.o
CC core/ipv6/mld6.o
CC library/md.o
CC src/crypto/dh_groups.o
CC core/ipv6/nd6.o
CC core/ipv6/ip6.o
CC library/rsa.o
CC src/crypto/md4-internal.o
CC core/ipv6/ip6_addr.o
CC src/crypto/sha1-internal.o
CC library/ripemd160.o
CC core/ipv6/inet6.o
CC core/ipv6/dhcp6.o
CC core/ipv6/ip6_frag.o
CC src/crypto/aes-wrap.o
CC netif/ethernetif.o
CC library/version_features.o
CC src/crypto/crypto_internal.o
CC netif/lowpan6.o
CC netif/ethernet.o
CC library/cipher.o
CC netif/etharp.o
CC src/crypto/dh_group5.o
CC netif/slipif.o
CC port/freertos/sys_arch.o
CC src/crypto/des-internal.o
CC library/entropy_poll.o
CC port/netif/ethernetif.o
CC src/crypto/crypto_internal-rsa.o
CC port/netif/wlanif.o
CC library/dhm.o
CC src/crypto/aes-unwrap.o
AR liblwip.a
CC library/error.o
CC src/crypto/aes-internal-dec.o
CC src/crypto/sha1.o
CC src/crypto/aes-internal.o
CC library/ssl_ticket.o
CC library/x509.o
CC src/crypto/md5-internal.o
CC src/crypto/sha256-internal.o
CC library/blowfish.o
CC library/ecp.o
CC src/crypto/aes-internal-enc.o
CC library/md4.o
CC port/os_xtensa.o
CC library/x509_csr.o
CC library/pkparse.o
AR libwpa_supplicant.a
CC library/pkcs5.o
CC library/ccm.o
CC library/pkcs12.o
CC library/pk_wrap.o
CC library/ecp_curves.o
CC library/x509write_crt.o
CC library/ctr_drbg.o
CC library/platform.o
CC library/pk.o
CC library/x509write_csr.o
CC library/des.o
CC library/hmac_drbg.o
CC library/sha1.o
CC port/esp_sha512.o
CC port/esp_hardware.o
CC port/esp_bignum.o
CC port/esp_sha256.o
CC port/net.o
CC port/esp_sha1.o
CC port/mbedtls_debug.o
AR libmbedtls.a
CC //main.o
CC drv/CAN/CAN.o
CC drv/CAN/cfg/CAN_config.o
AR libmain.a
LD CAN_demo.elf
To flash all build output, run 'make flash' or:
python /c/idf/2114/components/esptool_py/esptool/esptool.py --chip esp32 --port com21 --baud 921600 --before default_reset --after hard_reset write_flash -u --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 /home/sysop/testcan/build/bootloader/bootloader.bin 0x10000 /home/sysop/testcan/build/CAN_demo.bin 0x8000 /home/sysop/testcan/build/partitions_singleapp.bin
No vm.
Just Ubuntu Linux 16.10.
All other examples are being built without issues.
best regards
DL88AI88
best regards
DL88AI88
OK, I solved it like this:
in component.mk I changed
COMPONENT_ADD_INCLUDEDIRS := / drv/CAN/include
COMPONENT_SRCDIRS := / drv/CAN drv/CAN/cfg
to
COMPONENT_ADD_INCLUDEDIRS := . drv/CAN/include
COMPONENT_SRCDIRS := . drv/CAN drv/CAN/cfg
Now it compiles.
best regards
DL88AI88
to
Now it compiles.
best regards
DL88AI88
@jeroen
CAN Driver as component and menuconfig now online on my git
Pullrequest to the author is done
extended frames in work
rudi
Nice.
Dont't forget about those pesky RTR frames
Cheers
Cheers
Hans Dorn wrote:Nice.
german
http://translate.google.com
english
rudi
Users browsing this forum: No registered users and 116 guests
