esp-mdf mqtt cannot subscribe topic
Re: esp-mdf mqtt cannot subscribe topic
Found the issue - it is just the message syntax - it uses JSON format and if the syntax is not correct, it does not work. if you are on the root node, it will show "parse error"
I'm also facing the same issue. Is the problem resolved?
Users browsing this forum: No registered users and 55 guests
