esp_netif_receive eating all my ram (SLIP protocol) (IDFGH-4141)
fpena_inusual
Re: esp_netif_receive eating all my ram (SLIP protocol) (IDFGH-4141)
Postby fpena_inusual » Thu Oct 29, 2020 8:09 am
Hello again,
More info on the issue.
I've attached two log files, one contains the captured packets in wireshark and the other the output log from the esp32.
As you can see, the packet #25 is lost somewhere. For whatever reason it's received from the slip interface but it's not accepted on the ip4 layers, and my guess is that this packet is held in memory forever.
slipif_input: alloc
slipif: Got packet (40 bytes) <-- Here comes the lost packet
slipif_input: alloc
slipif: Got packet (40 bytes) <-- This is the retransmitted packet
ip_input: iphdr->dest 0x2f0a8c0 netif->ip_addr 0x2f0a8c0 (0xf0a8c0, 0xf0a8c0, 0x2000000)
ip4_input: packet accepted on interface sl
ip4_input:
IP header:
| 4 | 5 |  0x00 |        40     | (v, hl, tos, len)
|    19789      |010|       0   | (id, flags, offset)
|   64  |    6  |    0x8c2d     | (ttl, proto, chksum)
|  192  |  168  |  240  |    1  | (src)
|  192  |  168  |  240  |    2  | (dest)
ip4_input: p->len 40 p->tot_len 40
And it seems to happen on ever problematic packet.
I'll keep digging on it...
wireshark_capture_2.txt
(49.3 KiB) Downloaded 446 times
console_capture_2.log
(21.24 KiB) Downloaded 456 times
fpena_inusual
Postby fpena_inusual » Thu Oct 29, 2020 9:36 am
Ok, I think I've solved the isue :D
I traced back the problem to the slipif_proccess_rxqueue function in components/lwip/lwip/src/netif/slipif.c file of the esp-idf.
I actually didn't fix anything. I simply compared the function with the one used in the esp8266 SDK (that I used before as slip gateway) and made the same changes to it... and it worked flawlessly.
Here is the patch to this file:
--- a/components/lwip/lwip/src/netif/slipif.c	2020-10-29 09:39:59.444559678 +0100
+++ b/components/lwip/lwip/src/netif/slipif.c	2020-10-29 10:18:44.963390416 +0100
@@ -461,12 +461,8 @@
     struct pbuf *p = priv->rxpackets;
 #if SLIP_RX_QUEUE
     /* dequeue packet */
-    struct pbuf *q = p;
-    while ((q->len != q->tot_len) && (q->next != NULL)) {
-      q = q->next;
-    priv->rxpackets = q->next;
-    q->next = NULL;
+    priv->rxpackets = p->next;
+    p->next = NULL;
 #else /* SLIP_RX_QUEUE */
     priv->rxpackets = NULL;
 #endif /* SLIP_RX_QUEUE */
@@ -497,7 +493,7 @@
     if (priv->rxpackets != NULL) {
 #if SLIP_RX_QUEUE
       /* queue multiple pbufs */
+      struct pbuf *q = priv->rxpackets;
       while (q->next != NULL) {
         q = q->next;
P.S.: I've also attached the patch file to this post.
slipif.patch.zip
(526 Bytes) Downloaded 476 times
ESP_cermak
Postby ESP_cermak » Wed Dec 02, 2020 3:42 pm
@fpena_inusual Any update on your issue? I've received a patch on esp-lwip fixing pbub links on the SLIP interface. Not sure if it helps fixing your issues, but seems like worth trying. (if it wasn't you who posted the PR)
ESP_cermak
Postby ESP_cermak » Wed Dec 02, 2020 6:27 pm
Oh, thanks for the update and for posting the fix! It looks like the same as posted here https://github.com/espressif/esp-lwip/pull/25.
Users browsing this forum: twompark and 74 guests
