A2DP panic problem
quenolio
A2DP panic problem
Postby quenolio » Mon Nov 02, 2020 9:06 am
Hey everyone!
I am working on creating my own voice assistant using IDF and ADF libraries. The application also uses such libraries as sh2lib (from protocols/http2 example), ESP-DSP and Tensorflow Lite. Moreover, the assistant can play music via A2DP stream (code taken from advanced_examples/wifi_bt_ble_coex example). And here a problem arises, because the application ran smoothly for about 48h and then the program broke down with the following Panic Handler:
Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC      : 0x4024994c  PS      : 0x00060630  A0      : 0x80248a48  A1      : 0x3f974a40
0x4024994c: fa_resample_process at /Users/maojianxin/duros/esp-adf-libs-source/esp_processing/esp-resample/src_fa/fa_resample.c:2935
A2      : 0x00000002  A3      : 0x00000230  A4      : 0x3f974c24  A5      : 0x3f975038
A6      : 0x00000002  A7      : 0x3f971ecc  A8      : 0x8021b3c5  A9      : 0x3f974a80
A10     : 0x3fff48cc  A11     : 0x3f958c18  A12     : 0x00000400  A13     : 0x3f975024
A14     : 0x0596ff0e  A15     : 0x00000000  SAR     : 0x0000000f  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000230  LBEG    : 0x40099488  LEND    : 0x400994b6  LCOUNT  : 0x00000000
0x40099488: memcpy at /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memcpy.S:168
0x400994b6: memcpy at /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memcpy.S:201
ELF file SHA256: 1bdb9c040599c67e
Backtrace: 0x4024994c:0x3f974a40
CPU halted.
At the time of the bug, on a device worked a thread from:
  • The A2DP music stream
  • Websocket requests handling
  • HTTP2 requests handling (which waited for a new request using xTaskNotifyWait)
  • Wake-word recognition thread which only performed vTaskDelay, due to muted microphones (which resulted in suspension of calculations)
  • Recorder Engine Task to collect new audio data from I2S (Recorder Engine in only VAD mode)
I use ADF v2.1 and the attached IDF v3.3.2 library.
Does anyone know what the problem may be or experienced similar behavior, or can they advise me how to fix it?
Users browsing this forum: No registered users and 18 guests
