我的需求是:一组esp32,烧录完全相同的代码,在上电时自动组成ble mesh网络,目前有两个想法:
1. 能否直接把NetKey和AppKey写到代码中,从而跳过provisioning过程,上电便自动组网?
2. 能否通过修改fast provision例程,去掉手机配置的环节,直接上电就自动配置周围的设备,从而形成一个网络?
一组esp32 ble mesh设备能否实现上电自动配网?
Re: 一组esp32 ble mesh设备能否实现上电自动配网?
Hi jayant97,
ESP BLE Mesh provides some functions for test, and one of them is to bypass the provisioning procedure.
The function is "bt_mesh_device_auto_enter_network" which is in components/bt/esp_ble_mesh/mesh_core/test.c
In the application layer, users can use this function to enable entering mesh network automatically for the unprovisioned devices.
But this function is only used for test, as for a production, the provisioning procedure is mandatory.
Thanks.
Users browsing this forum: No registered users and 59 guests
