Hello, I am trying to create a BLE peripheral on a ESP32-SOLO-1 using NimBLE Stack. I have successfully created characteristics and I am able to read and write on them, but I can't notify new values to the client.
I have configured the characteristic with read, write and notify flags (.flags = BLE_GATT_CHR_F_READ | BLE_GATT_CHR_F_WRITE | BLE_GATT_CHR_F_NOTIFY) and I try to use ble_gatts_chr_updated(notifiedCharHandle) to notify the client, but the client does not receive the notification. I see that the function returns a 7 as an error identifier, but I can't find the meaning of it.
Thanks in advance,
Jon
BLE characteristic notification under NimBLE stack
Re: BLE characteristic notification under NimBLE stack
As an update, I am trying to know what do I need to do when a client registers for notification. At the moment I do nothing when I get the BLE_GAP_EVENT_SUBSCRIBE event. I should register the connection somewhere to know which connections are registered and which not, but I cant find how.
As a follow up, I solved this issue adding a characteristic handle variable to the services' definition structure.
Once the characteristic is registered, the variable charHandle holds the characteristic handle and this can be used to call ble_gatts_chr_updated(charHandle) to notify all connected device about value changes on the characteristic.
static const struct ble_gatt_svc_def services[] = {
.type = BLE_GATT_SVC_TYPE_PRIMARY,
.uuid = &serviceUUID.u,
.characteristics = (struct ble_gatt_chr_def[])
.uuid = &characteristicUUID.u,
.access_cb = ble_accessCallback,
.val_handle = &charHandle, /* I added this pointer to hold the characterisitc handle */
.flags = BLE_GATT_CHR_F_READ | BLE_GATT_CHR_F_READ_ENC | BLE_GATT_CHR_F_WRITE | BLE_GATT_CHR_F_WRITE_ENC | BLE_GATT_CHR_F_NOTIFY,
0,
0,
Users browsing this forum: Google [Bot] and 58 guests
