Using bluetooth serial and pausing/killing core zero
av4625
Postby av4625 » Mon Jun 22, 2020 12:40 pm
I am using bluetooth serial to read obd data from a car and this task is running on core zero.
Core 1 shows the data.
This all works as expected.
When I get user input on a rotary encoder I want to pause the bluetooth task on core zero, do some settings work, when the settings work is over I want to resume task zero.
I tried using
vTaskSuspend
then
vTaskResume
I also tried using
vTaskDelete
then recreating with
xTaskCreatePinnedToCore
When I either
vTaskResume
or
the bluetooth connection has dropped. Is there anyway to pause and resume a bluetooth connection?
Re: Using bluetooth serial and pausing/killing core zero
Postby ESP_Sprite » Tue Jun 23, 2020 8:06 am
What exactly is it that you want to pause/resume? The incoming data stream?
Users browsing this forum: Bing [Bot] and 107 guests
