Can't tell linker to exclude stripping several functions
julienD
Postby julienD » Thu Jun 04, 2020 10:17 am
I have several components in my project. Some of them are using functions from others.
In order to avoid compiler to strip the functions that are not used by the main component, I use the -u option like this:
main's CMakeLists.txt :
<snip>
target_link_options(
	${COMPONENT_LIB}
	PUBLIC
	-u SpiInOut
and this works as expected, no more "undefined reference".
Now, if I want to add several functions, I do something like this :
	${COMPONENT_LIB}
	PUBLIC
	-u SpiInOut
        -u memcpy1
This does not work because, CMake, generates this command line :
<snip> -u SpiInOut memcpy1
While it should be
<snip> -u SpiInOut -u memcpy1
How should I do?
Julien
ESP_renz
Re: Can't tell linker to exclude stripping several functions
Postby ESP_renz » Thu Jun 04, 2020 10:45 pm
Can you try enclosing them in quotes?
	${COMPONENT_LIB}
	PUBLIC
	"-u SpiInOut" "-u memcpy1"
P.S. Note `target_link_options` requires at least a CMake version > 3.13.
julienD
Postby julienD » Mon Jun 08, 2020 1:20 pm
It doesn't work.
Command line becomes:
&& /home/ju/tools/crosstool-NG/builds/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++  -mlongcalls -Wno-frame-address  "-u memcpy1" "-u SpiInOut" "-u DelayMs" CMakeFile
as a result : undefined reference to SpiInOut...
ESP_renz
Postby ESP_renz » Tue Jun 09, 2020 12:01 am
On the contrary, it means that the `-u` argument for `SpiInOut` works, since you're forcing the linker to not drop `SpiInOut` but it is not finding it. Is the source file containing definition for `SpiInOut` is included in the build?
Users browsing this forum: Bing [Bot] and 61 guests
