ESP32 unable to execute uploaded program
Kevintan1998
Postby Kevintan1998 » Mon Jun 01, 2020 2:44 am
I have been working on a project using the ESP32 module for a while, but recently I discover my module is behaving abnormally. Whenever I upload codes to the module, it would not execute the program but only display the below message in the serial monitor:
configsip: 0, SPIWP:0xee
mode:DOUT, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:8896
load:0x40080400,len:5816
entry 0x400806ac
ets Jun  8 2016 00:22:57
Can I know the meaning of this message and if possible, the method the fix it. By the way, I am programming the module using the Arduino IDE software. The model I am using is ESP32 Node32S.
Agree007
Re: ESP32 unable to execute uploaded program
Postby Agree007 » Mon Jun 01, 2020 7:16 am
Please share you code and name/model of you esp32 module ?
It looks like a memory or watchdog issue.
Kevintan1998
Postby Kevintan1998 » Tue Jun 02, 2020 2:14 am
The model that I use is ESP32 Node32S and this is the code I am currently using it to test my module:
#define ONBOARD_LED 2
//const int led2Pin = 19;
void setup() {
  Serial.begin(115200);
  pinMode(ONBOARD_LED,OUTPUT);
void loop() {
  digitalWrite(ONBOARD_LED,HIGH);
It is a simple code used to blink the onboard LED, although it is not working right now. For additional information, previously the module can run longer programs. The problem I mentioned at first appeared after the module suddenly heat up for a while. Programs can be uploaded but cannot successfully execute.
pipi61
Postby pipi61 » Tue Jun 02, 2020 11:25 am
This not a blink.
try, and check serial console:
void loop() {
Serial.print(".");
delay (1000);
digitalWrite(ONBOARD_LED,LOW);
delay (1000);
Kevintan1998
Postby Kevintan1998 » Wed Jun 03, 2020 2:10 am
I tried both pipi61 and chegewara recommendation, but it seems the device is still in the same condition. I even try to erase the flash memory but the method is not working. Since the module is returning responses, I assume it can still be fixed?
lbernstone
Postby lbernstone » Wed Jun 03, 2020 3:40 pm
Hold down gpio0, then press the reset button. This will put it into download mode.
Now you can flash or erase.
Kevintan1998
Postby Kevintan1998 » Thu Jun 04, 2020 2:09 am
I tried lbernstone method. By forcing it into the download mode, I proceed to erase the flash. Now I am getting a new error response:
flash read err, 1000
ets_main.c 371
Just what is the meaning of this new error message?
chegewara
Postby chegewara » Thu Jun 04, 2020 6:51 am
It means that flash memory is erased, nothing to run.
Kevintan1998
Postby Kevintan1998 » Mon Jun 08, 2020 2:37 am
I try to upload any program to the board, but it still produces the same response. I assume to damage of the board is beyond repair?
Users browsing this forum: Majestic-12 [Bot] and 94 guests
