WIFI_MODE_APSTA Sample
Re: WIFI_MODE_APSTA Sample
@imtiaz:
nice that You found a solution for this problem!
Would You be so nice to share it so that also other people are delighted?
kind regards
Squonk
kind regards
Squonk
"Whoever believes to be someone has stopped becoming someone"
Sokrates
Sokrates
its not the most ideal solution but works well:
@Inputs:
@Outputs:
@Comments:
void Start_wifi(wifi_config_t* wifi_config , wifi_mode_t Mode )
wifi_mode_t currentMode;
if(esp_wifi_get_mode(¤tMode) == ESP_ERR_WIFI_NOT_INIT)
wifiSetup_Init();
else if(currentMode == WIFI_MODE_APSTA)
ESP_LOGE(TAG,"wifi APSTA already running\n");
return;
else if(currentMode == Mode)
ESP_LOGE(TAG,"that mode is already running\n");
return;
else
esp_wifi_stop();
if(currentMode == WIFI_MODE_AP && Mode == WIFI_MODE_STA)
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_APSTA) );
else if(currentMode == WIFI_MODE_STA && Mode == WIFI_MODE_AP)
else
ESP_ERROR_CHECK( esp_wifi_set_mode(Mode) );
if(Mode == WIFI_MODE_AP)
ESP_ERROR_CHECK( esp_wifi_set_config(ESP_IF_WIFI_AP, wifi_config) );
else if(Mode == WIFI_MODE_STA)
ESP_ERROR_CHECK( esp_wifi_set_config(ESP_IF_WIFI_STA, wifi_config) );
ESP_ERROR_CHECK( esp_wifi_start());
@Inputs:
@Outputs:
@Comments:
void wifiSetup_StopSTA(void)
esp_wifi_get_mode(¤tMode);
if(currentMode == WIFI_MODE_STA )
esp_wifi_stop();
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_NULL) );
else if (currentMode == WIFI_MODE_APSTA)
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_AP) );
@Inputs:
@Outputs:
@Comments:
void wifiSetup_StopAP(void)
if(currentMode == WIFI_MODE_AP )
esp_wifi_stop();
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
@Inputs:
@Outputs:
@Comments:
void Kill_wifi(void)
esp_wifi_stop();
//vEventGroupDelete(wifi_event_group);
esp_wifi_deinit();
@Inputs:
@Outputs:
@Comments:
void wifiSetup_Init(void)
ESP_LOGI(TAG,"Initilising TCP and wifi\n");
tcpip_adapter_init();
wifi_event_group = xEventGroupCreate();
if(esp_event_loop_init(event_handler, NULL) == ESP_FAIL)
ESP_LOGI(TAG,"Event Loop not created , may have been created before \n");
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK( esp_wifi_init(&cfg) );
ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
esp_wifi_set_mode(0);
Thank You for Your fast answer. But unfortunately the most importent thing for me is missing:
How do You populate the union "wifi_config_t"?
Sokrates
Sokrates
Ummm - well there is no magic there , just look at some of the example code. Important thing is that if you are configuring an AP , then populate wifiConfig.ap , if you are configuring as a STA then populate wifiConfig.sta , then call
or
You only need to do one or the other. If you want to stop
Hope that helps.... In my case these commands are coming in externally through the uart so I cant really paste any code.. suffice to say its straight forward.
Start_wifi(&wifiConfig , WIFI_MODE_AP);
Start_wifi(&wifiConfig , WIFI_MODE_STA);
wifiSetup_StopAP();
wifiSetup_StopSTA();
o.k. thank you. Now it's clear and it works. Thanks a lot.
Now I am trying to obtain infos (e.g. ssid(s) or IPs) of the stations connected to my AP. I found an example on that using "esp_wifi_get_station_list". But this does not seem to work because this function does not seem to be available in ESP-IDF (any more)?
Do you have another suggestion how to do this?
Sokrates
Sokrates
I found a solution how to find the IP:
wifi_sta_list_t stations;
ESP_ERROR_CHECK(esp_wifi_ap_get_sta_list(&stations));
tcpip_adapter_sta_list_t infoList;
ESP_ERROR_CHECK(tcpip_adapter_get_sta_list(&stations, &infoList));
int i = 0;
while(i < infoList.num) {
printf("mac: %.2x:%.2x:%.2x:%.2x:%.2x:%.2x " IPSTR " %d\n",
infoList.sta[i].mac[0],infoList.sta[i].mac[1],infoList.sta[i].mac[2],
infoList.sta[i].mac[3],infoList.sta[i].mac[4],infoList.sta[i].mac[5],
IP2STR(&(infoList.sta[i].ip)),
(uint32_t)(infoList.sta[i].ip.addr));
i++;
Sokrates
Sokrates
can you publish entire code for master and slave working at the same time accesspoint for (esp_now) and station mode to connect to a wifi ? many people talks but there are no WORKING SAMPLE !!!!
Thanks guys
Thanks guys
I am looking into arduino sample for esp32. There is:
#define WiFiMode_t wifi_mode_t
#define WIFI_OFF WIFI_MODE_NULL
#define WIFI_STA WIFI_MODE_STA
#define WIFI_AP WIFI_MODE_AP
#define WIFI_AP_STA WIFI_MODE_APSTA
So I can assume there is
AccessPoint mode
Station mode
and
AcccessPoint and Station mode
Is my assumption correct?
Also I want to know if it is possible to have sample for WIFI_MODE_APSTA.
AccessPoint mode
Station mode
and
I also facing the same issue with esp32, I tried to configure both STA and AP and same but Station is connecting but when I tired to connect with AP mode it is not connecting. im using Arduino IDE here is my code please help me
#include <WiFiClient.h>
#include <ESP32WebServer.h>
#include <WiFi.h>
#include <ESPmDNS.h>
const char* ssid = "TEST1234";
const char* password = "test1234";
const char* ssidAP = "TIMER_SWITCH";
const char* passwordAP = "timer_test";
ESP32WebServer server(80);
const int led = 13;
void handleRoot() {
digitalWrite(led, 1);
server.send(200, "text/plain", "hello from ESP32!");
digitalWrite(led, 0);
void handleNotFound(){
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++){
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
void setup(void){
pinMode(led, OUTPUT);
Serial.begin(115200);
WiFi.mode(WIFI_MODE_APSTA);
WiFi.begin(ssid, password,6);
WiFi.softAP(ssidAP, passwordAP,6);
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
if (MDNS.begin("esp32")) {
Serial.println("MDNS responder started");
server.on("/", handleRoot);
server.on("/inline", [](){
server.send(200, "text/plain", "this works as well");
server.onNotFound(handleNotFound);
server.begin();
Serial.println("HTTP server started");
void loop(void){
server.handleClient();
#include <WiFi.h>
const int led = 13;
void handleRoot() {
message += "URI: ";
message += "\n";
void setup(void){
delay(500);
Serial.print(".");
Serial.println("");
server.begin();
void loop(void){
Can you please share the code? I am confused with event_handler function. which cases should we use in event handler?
Thanks and Best regards,
Bhakti Deshpande.
Bhakti Deshpande.
Users browsing this forum: MicroController and 98 guests
