I2C maximum data rate
Yakir533
Postby Yakir533 » Thu Mar 02, 2017 3:25 pm
Im intresting in your new product esp32.
I read on the data sheet about the I2C interface.
I saw that there are two options of data rate, 100kb/s (standart), 400kb/s (fast).
I want to know if there any option to work with the I2C with higer data rates?, and if so what is the maximum data rate?
Thanks!
Jakobsen
Re: I2C maximum data rate
Postby Jakobsen » Thu Mar 02, 2017 6:10 pm
Hello Yakir
I did try to push i2c com speed and did not see any problem setting up the driver to 800 kbps. Communication was ok - if you have the right (externl) pull on the i2c bus.
I did notice that one of the clock pulses (between data and ack ) do not seem to get scaled with the faster clock setting - Still need to report to Espressif.
Regards Jørgen
Plot of 400kbps with extra delay between last data and the ack clock
Analog Digital IC designer / DevOps @ Merus Audio, Copenhagen, Denmark.
We do novel and best in class Audio amplifiers for consumer products.
Programmed assembler for C-64 back in 1980's, learned some electronics - hacking since then
Users browsing this forum: ESP_rrtandler and 76 guests
