ESP32 LyraT v4.3 Aux input circuit is highly confusing and surely wrong
danak6jq
Re: ESP32 LyraT v4.3 Aux input circuit is highly confusing and surely wrong
Postby danak6jq » Fri Oct 11, 2019 4:11 pm
Thank you!
Dana
Horst Schlawutzke
Postby Horst Schlawutzke » Wed May 20, 2020 4:54 am
Hello there and thnks for the topic,
in order to remove the caps, would you hint me to locate them?
I can't find a pcb layout, so in the moment I am stuck.
bobolink
Postby bobolink » Wed May 20, 2020 11:31 am
I’m interested in this topic as well.
Dana,
Does the AI-Thinker board have these parts?
Bob
danak6jq
Postby danak6jq » Wed May 20, 2020 3:33 pm
It's true the PCB has no silkscreen; fortunately, the "ESP32-LyraT Getting Started Guide" contains a link to a component layout:
https://dl.espressif.com/dl/schematics/ ... layout.pdf
Locate and remove C62, C64, C65 and C66. It is perhaps easiest to find these initially using text search in the component layout PDF.
Cheers,
Dana
danak6jq
Postby danak6jq » Wed May 20, 2020 3:34 pm
Dana,
Bob
I can confirm that the AI-Thinker dev boards that I have, do not have these parts.
Cheers,
Dana
danak6jq
Postby danak6jq » Wed May 20, 2020 6:31 pm
Cheers,
Dana
This image may help.
https://drive.google.com/open?id=1XFEvd ... l11c7Yah-F
Cheers,
Dana
Horst Schlawutzke
Postby Horst Schlawutzke » Thu May 21, 2020 8:02 pm
Cheers,
Dana
Dana, my hero!
(probably the best answer I ever got from a forum)
regards Horst
danak6jq
Postby danak6jq » Fri May 22, 2020 3:48 am
Dana, my hero!
regards Horst
Aw, you'll make me blush! I'm glad that I could help.
Cheers,
Dana
nat250s
Postby nat250s » Mon Dec 06, 2021 5:57 pm
Any update on this issue? I am now running into this problem using aux in for a project I am working with. Removal of the specified capacitors helps but doesn't eliminate the issue.
https://github.com/ns96/cassetteflow
crosswick
Postby crosswick » Mon Jan 15, 2024 10:02 am
There is another pretty huge issue with the standard passthru example which also affects audio quality for some reason, and hasn't been fixed for years...
Basically the audio is only passed through the audio codec mixer and never even reaches the ESP32. This is what fixed it for me:
https://github.com/espressif/esp-adf/is ... -578473334
Users browsing this forum: No registered users and 113 guests
