esp32-s2 usb driver
esp32-s2 usb driver
hello,
i connected the esp32-s2-sola-1 v1.2 board to computer with gpio19 and gpio 20, then press boot key and reset the board.
the computer can find the esp32-s2 chip,but dont have cdc driver, i can not find the windows driver on website and the form,
can you provide that?
Re: esp32-s2 usb driver
Which Windows version is this for?
sorry for my late reply. my windows is win10 64
That is interesting... Is your Windows install up-to-date? As far as I'm aware, Windows 10 should automatically see the device as a CDC device and install the proper driver. (You probably still will see another unsupported device, this is the DFU device and unfortunately we do not have drivers for that at this point in time.)
thanks your reply, if no need driver in your side, i can try another computer.
thanks the information.
Having now populated some prototype designs using the ESP32-S2-WROOM, all display the same issue with lack of Windows 10 driver, and on different PCs.
This occurs when going into programming mode ready for flashing via USB.
Did anyone find a resolve for this please?
Many thanks
Dave
Many thanks
Dave
- ESP32-S2 USB Driver Issue.JPG (12.97 KiB) Viewed 42666 times
- ESP_Roland
Hi DitroniX,
you should be able install WinUSB driver for ESP32-S2 with https://zadig.akeo.ie/. However, flashing via USB is not yet supported by ESP-IDF.
Many thanks for this feedback. Will investigate and also await updated ESP-IDF in due course.
We played a bit with the USB interface of the ESP32-S2 in ROM bootloader mode.
https://youtu.be/s9r2c-85UJM
Indeed you should get automatically a serial COM: (on windows) for the CDC-ACM.
In addition the chip in bootmode also exposes a DFU interface (see in the video). That needs probably a driver on windows. In OS X or linux you can access it via a generic usb library.
This is interesting and thanks for the video link. Look forward to an update to allow the native USB to work.
Users browsing this forum: Tanguy and 76 guests
