Thanks for the hint - No no sign of an APLL enabled by that call. Parameter change did do something but not any thing deterministic - and still a lot of jitter on BCK
/j
Jakobsen wrote:Hi WiFive
/j
perhabs it helps you
rtc_clk.o rtc_xtal_32k_ena
rtc_clk.o rtc_8m_ena
rtc_clk.o rtc_plla_ena
rtc_clk.o rtc_set_slow_freq
rtc_clk.o rtc_set_fast_freq
rtc_clk.o rtc_bbpll_md
rtc_clk.o rtc_init_xtal_freq
rtc_clk.o rtc_get_xtal
rtc_clk.o rtc_apb_freq_up
rtc_clk.o rtc_uart_div_modify
rtc_clk.o rtc_uart_tx_wait_idle
rtc_clk.o rtc_set_cpu_freq
rtc_clk.o rtc_init_clk
rtc_clk.o rtc_init_clk_lite
rtc_plla_ena(1, 0, 255, 0, 0); // 2.5MHz
Any progress?Jakobsen wrote:
O yes - need more coffee - i did commit - as I use to on SVN but i see there is more to it then that.
I will try to follow you description tonight and have added git to my bucket list.
Any progressBuddyCasino wrote:Its going to be on Github as soon as I got it to work.
I'm sending a multipart http message (json + pcm audio) to the Alexa endpoint, but they reset the connection and I have no idea why. When I interrupt my data sending by returning NGHTTP2_ERR_DEFERRED from my data_source_read_callback() to give nghttp2 time to read from the socket to maybe retrieve some error message that would help me, I only get a settings frame and after that its "mbedtls_ssl_write returned -0x50", which means the peer reset the connection.Any progress
Where are you stuck
return ESP_FAIL;
clkmInteger = clkmdiv;
clkmDecimals = (clkmdiv - clkmInteger) / denom;
float mclk = clkmInteger + denom * clkmDecimals;
bck = factor/(bits * channel);
// rtc_plla_ena(1, 0, 0,1 , 0);
I2S[i2s_num]->clkm_conf.clka_en = 1; // jkj was 0
I2S[i2s_num]->clkm_conf.clkm_div_a = 63;
I2S[i2s_num]->clkm_conf.clkm_div_b = clkmDecimals;
Users browsing this forum: No registered users and 29 guests
