How to trigger GPIO with traceTASK_SWITCHED_IN()
dave_see
Postby dave_see » Thu Apr 16, 2020 1:05 pm
I was reading about the FreeRTOS macros traceTASK_SWITCHED_IN() and traceTASK_SWITCHED_OUT() at this link from freertos.org:
https://www.freertos.org/rtos-trace-macros.html
I'd like to use the macros to drive GPIO pins to debug task behavior. I'm able to set a pin for each task with vTaskSetApplicationTaskTag.
To set the trace macros, I try to include "driver/gpio.h" at the end of "FreeRTOSConfig.h". When I try to do that, I get a lot of build errors starting with:
~/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/sys-include/machine/_default_types.h:41: Error: unknown opcode or format name 'typedef'
It seems I can't include "driver/gpio.h" in "FreeRTOSConfig.h".
Is it possible to use traceTASK_SWITCHED_IN() and traceTASK_SWITCHED_OUT() to drive GPIO pins with ESP-IDF?
Many thanks,
Dave
ESP_igrr
Re: How to trigger GPIO with traceTASK_SWITCHED_IN()
Postby ESP_igrr » Thu Apr 16, 2020 3:58 pm
dave_see wrote:Error: unknown opcode or format name 'typedef'
This happens because FreeRTOSConfig.h is also included from assembly sources (.S). You can add #ifndef __ASSEMBLER__ // #endif around your extra include header.
A more lightweight alternative is to add a forward declaration of the function you require (again, inside ifndef __ASSEMBLER). This way you won't be pulling in the whole gpio.h and other headers it might depend on.
int32_t gpio_set_level(int, uint32_t);
#endif // __ASSEMBLER__
dave_see
Postby dave_see » Thu Apr 16, 2020 7:49 pm
Hi ESP_igrr,
Thank you for your suggestion!
I have it working now and my FreeRTOSConfig.h file looks like this:
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
#include "sdkconfig.h"
/* ACTUAL FreeRTOSConfig.h THINGS HERE */
#define traceTASK_SWITCHED_IN() { \
    if( (int)pxCurrentTCB[ xPortGetCoreID() ]->pxTaskTag > 0 ) \
        gpio_set_level((int)pxCurrentTCB[ xPortGetCoreID() ]->pxTaskTag, 1); \
#define traceTASK_SWITCHED_OUT() { \
        gpio_set_level((int)pxCurrentTCB[ xPortGetCoreID() ]->pxTaskTag, 0); \
#endif /* FREERTOS_CONFIG_H */
Thanks again!
-Dave
Users browsing this forum: Bing [Bot], REEASD, snutw_ and 157 guests
