ESP32 SD card info
- Segmentation Fault
ESP32 SD card info
I've been making a project with my ESP8266 with an additional SD card module using Arduino IDE.
My project required an upgrade, so I purchased and ESP32-WROVER-KIT and am trying to get the SD card information, but I cannot find something similar with the ESP8266 SdFat.h for the ESP32.
Is there a way to get in ESP32 the card info (type, size, manufacturer, partitions etc) like the cardInfo example of ESP8266?
Re: ESP32 SD card info
To answer for other people might needing this; the ESP32 library for Arduino IDE does not seem to include the required files, but they can be downloaded from here: https://github.com/greiman/SdFat
It seems to be almost the same as with ESP8266, except that "using namespace sdfat;" will cause a compilation error. I also added #define FS_NO_GLOBALS to avoid another compilation error and now the code compiles fine for ESP-WROVER.
I have not uploaded and tested it yet. I will post an update as soon as I do.
I cannot initialize the sdfat.
SD_INFO gives:
PARTITION_INFO:
VOLUME_INFO gives:
This is my code:
I am suspecting I should define the SD SPI bus of the WROVER in the SdFat class as well, but I cannot find how to define the SPI GPIO pins there.
Any help would be really appreciated,
SD_INFO gives:
error: File System initialization failed.
SD errorCode: 0X50,0X0
gives error: read MBR failed
error: cardBegin failed
SD errorCode: 0X20,0XFF
#include <SdFat.h>
#include <sdios.h>
#include <My_Receive_serial_lib.h>
#include <SPI.h>
#include <SD.h>
static bool hasSD = false;
fs::File uploadFile;
#define USE_SDIO 0
#if USE_SDIO
// Use faster SdioCardEX
SdFatSdioEX sd;
#else // USE_SDIO
SdFat sd;
#endif // USE_SDIO
#define SD_CS 13
void setup()
Serial.begin(SERIAL_BAUD_RATE);
SPI.begin(14, 2, 15, 13); // The bultin SD card SPI for WROVER
void loop()
if (Serial.available() > 0)
String IncomingData = Recieve_serial();
if (IncomingData == "SD_INFO" )
cidDmp();
else if (IncomingData == "PARTITION_INFO" )
partDmp();
else if (IncomingData == "VOLUME_INFO" )
volDmp();
uint8_t cidDmp()
Serial.println("-----------------");
Serial.println("Initialising card:");
uint32_t t = millis();
#if USE_SDIO
if (!sd.cardBegin(SD_CS))
Serial.print("cardBegin failed in #if USE_SDIO");
sdErrorMsg("\ncardBegin failed");
return 0;
#else // USE_SDIO
// Initialize at the highest speed supported by the board that is
// not over 50 MHz. Try a lower speed if SPI errors occur.
if (!sd.cardBegin(SD_CS, SD_SCK_MHZ(50)))
Serial.print("cardBegin failed in #else (of #if USE_SDIO)");
sdErrorMsg("cardBegin failed");
return 0;
else
if (!sd.fsBegin())
sdErrorMsg("\nFile System initialization failed.\n");
return 0;
#endif // USE_SDIO
t = millis() - t;
float cardSize2;
float freeSpace;
cardSize = sd.card()->cardSize();
if (cardSize == 0)
sdErrorMsg("cardSize failed");
return 0;
else
cardSize2 = 0.000512 * cardSize / 1024.0;
freeSpace = 0.000512 * sd.vol()->blocksPerCluster() * (uint32_t)sd.vol()->freeClusterCount() / 1024.0;
Serial.print("init time: ");
Serial.print(t); Serial.println("ms");
Serial.print("Card type: ");
switch (sd.card()->type())
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
break;
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
break;
case SD_CARD_TYPE_SDHC:
if (cardSize < 70000000)
Serial.println("SDHC");
else
Serial.println("SDXC");
break;
default:
Serial.println("Unknown");
cid_t cid;
if (!sd.card()->readCID(&cid))
sdErrorMsg("readCID failed");
return 0;
else
Serial.println("SD card initialised successfully.");
//Serial.println("-----------------");
Serial.println("Card INFO:");
Serial.print("Card size: "); Serial.print(cardSize2); Serial.println(" GB");
Serial.print("Free space: "); Serial.print(freeSpace); Serial.println(" GB");
Serial.print("Card clusters: "); Serial.println(cardSize);
Serial.print("Manufacturer ID: "); Serial.print("0x"); Serial.println(cid.mid, HEX);
Serial.print("OEM ID: "); Serial.println(cid.oid[0] << cid.oid[1]);
Serial.print("Product: ");
for (uint8_t i = 0; i < 5; i++)
Serial.print(cid.pnm[i]);
} Serial.println();
Serial.print("nVersion: "); Serial.print(cid.prv_n); Serial.print("."); Serial.println(cid.prv_m);
Serial.print("Serial number: "); Serial.println(cid.psn, HEX);
Serial.print("Manufacturing date: "); Serial.print(cid.mdt_month); Serial.print("/"); Serial.println(2000 + cid.mdt_year_low + 10 * cid.mdt_year_high);
uint32_t ocr;
if (!sd.card()->readOCR(&ocr))
sdErrorMsg("\nreadOCR failed");
return 0;
Serial.print("OCR: "); Serial.print("0x"); Serial.println(ocr, HEX);
uint8_t csdDmp()
csd_t csd;
uint8_t eraseSingleBlock;
if (!sd.card()->readCSD(&csd))
sdErrorMsg("readCSD failed");
return false;
if (csd.v1.csd_ver == 0)
eraseSingleBlock = csd.v1.erase_blk_en;
eraseSize = (csd.v1.sector_size_high << 1) | csd.v1.sector_size_low;
else if (csd.v2.csd_ver == 1)
eraseSingleBlock = csd.v2.erase_blk_en;
eraseSize = (csd.v2.sector_size_high << 1) | csd.v2.sector_size_low;
else
Serial.println("csd version error");
return false;
eraseSize++;
Serial.print("flashEraseSize: "); Serial.print(eraseSize); Serial.println(" blocks");
Serial.print("eraseSingleBlock: ");
if (eraseSingleBlock)
Serial.println("true");
else
Serial.println("false");
uint8_t partDmp()
#if USE_SDIO
if (!sd.cardBegin()) {
return 0;
#else // USE_SDIO
if (!sd.cardBegin(SD_CS, SD_SCK_MHZ(50))) {
return 0;
#endif // USE_SDIO
mbr_t mbr;
if (!sd.card()->readBlock(0, (uint8_t*)&mbr))
sdErrorMsg("read MBR failed");
return false;
Serial.println("Part INFO:");
for (uint8_t ip = 1; ip < 5; ip++)
part_t *pt = &mbr.part[ip - 1];
if ((pt->boot & 0X7F) != 0 || pt->firstSector > cardSize)
Serial.println("No MBR. Assuming Super Floppy format.");
return true;
Serial.println("SD Partition Table");
Serial.println("part,boot,type,start,length");
Serial.print(ip); Serial.print(",0x"); Serial.print(pt->boot, HEX); Serial.print(","); Serial.print(pt->type);
Serial.print(","); Serial.print(pt->firstSector); Serial.print(","); Serial.print(pt->totalSectors); Serial.println();
return true;
void volDmp()
#if defined (ARDUINO_ESP8266_NODEMCU)
#if USE_SDIO
return;
#else // USE_SDIO
return;
#endif // USE_SDIO
#elif defined (ARDUINO_ARCH_ESP32)
return;
#endif
if (!sd.fsBegin())
return;
Serial.println("cardBegin failed");
return;
Serial.println("Volume INFO:");
// float cardSize2 = float((0.000512*cardSize) >> 10); Does not work because of float and bit shifting
// float freeSpace = float((0.000512*sd.vol()->blocksPerCluster()*(uint32_t)sd.vol()->freeClusterCount())>>10); Does not work because of float and bit shifting
float cardSize2 = 0.000512 * cardSize / 1024.0;
float freeSpace = 0.000512 * sd.vol()->blocksPerCluster() * (uint32_t)sd.vol()->freeClusterCount() / 1024.0;
uint32_t volFree2 = sd.vol()->freeClusterCount();
Serial.print("Volume is FAT"); Serial.println(sd.vol()->fatType());
Serial.print("blocksPerCluster: "); Serial.println(sd.vol()->blocksPerCluster());
Serial.print("totalClusters: "); Serial.println(cardSize);
Serial.print("clusterCount: "); Serial.println(sd.vol()->clusterCount());
Serial.print("freeClusters: "); Serial.println(volFree2);
// float fs = 0.000512/1024.0*volFree*sd.vol()->blocksPerCluster();
// Serial.print("freeSpace: "); Serial.print(fs); Serial.println(" GB");
Serial.flush();
Serial.print("fatStartBlock: "); Serial.println(sd.vol()->fatStartBlock());
Serial.print("fatCount: "); Serial.println(sd.vol()->fatCount());
Serial.print("blocksPerFat: "); Serial.println(sd.vol()->blocksPerFat());
Serial.print("rootDirStart: "); Serial.println(sd.vol()->rootDirStart());
Serial.print("dataStartBlock: "); Serial.println(sd.vol()->dataStartBlock());
delay(100);
if (sd.vol()->dataStartBlock() > 0 % eraseSize)
Serial.println("Data area is not aligned on flash erase boundaries!");
//Serial.println("Download and use formatter from www.sdcard.org!");
csdDmp();
Last edited by Segmentation Fault on Mon Apr 13, 2020 10:30 pm, edited 2 times in total.
The pinout change in your source:
SPI.begin( 14, 2, 15, 13); // The bultin SD card SPI for WROVER
void begin (int8_t sck=-1, int8_t miso=-1, int8_t mosi=-1, int8_t ss=-1);// this SPI.begin defined in spi.h
Hi pipi61,
The SD class works properly after the pinout change SPI.begin( 14, 2, 15, 13);
The SdFat class though creates these errors.
I do not understand your reply.
sorry, i view sd, don"t sdfat.
Connect this pinout
CLK18, Miso19, Mosi23, CS15
and remove SPI.begin....
Connect this pinout
I cannot really do that. The SD card module is built in on the WROVER board and connected with the specific pinout.
Yes sdfat will work fine as he said.
It seems that it is a speed problem, not related with the WROVER pinout but with esp32.
Solution here:
https://github.com/greiman/SdFat/issues ... -396235386
Solution here:
Users browsing this forum: No registered users and 73 guests
