Esp32 and wifi laboratory test.
mrdebug
Postby mrdebug » Mon Apr 06, 2020 8:18 am
Hi, the new device based on esp32 is completed.
Now we have to make the wifi trasmissions test in an anechoic room.
I need a way to generate a sequence of wifi packets with a specified interfame time.
Can someone give me an example on how to do that?
Many thanks.
0xffff
Re: Esp32 and wifi laboratory test.
Postby 0xffff » Tue Apr 07, 2020 10:35 pm
Are you using the esp-idf or the Arduino IDE? If I understand correctly, seems like you should be able to slightly modify the standard Arduino IDE example such as https://github.com/espressif/arduino-es ... tBasic.ino to output whatever sequence you need with desire delay
mrdebug
Postby mrdebug » Wed Apr 08, 2020 6:08 am
Hi, I'm using esp-idf.
I need not only connect and disconnect but send custom packets.
Postby ESP_Sprite » Wed Apr 08, 2020 12:50 pm
You might be better off mailing sales@espressif.com for this.
Users browsing this forum: Baidu [Spider], ESP_igrr and 124 guests
