ESP32 WebServer doesn't respond / responds too late sometimes
MaGeIO
Postby MaGeIO » Mon Mar 16, 2020 2:16 pm
Hello there. I'm using a NodeMCU ESP32 as a webserver to controll a LED with my smartphone. It does work acutally and the webserver responds immediately most of the time but sometimes it just takes a few seconds or minutes to respond. Sometimes it doesn't even respond and I don't have any idea what the problem is. The website is just reloading / waitng for a respond and eventually gets the respond or gives me an "ERR_ADDRESS_UNREACHABLE" on the browser. Here is my code in the Arduino IDE (actually an example code from the IDE):
#include <WiFi.h>
const char* ssid     = "-";
const char* password = "-";
WiFiServer server(80);
void setup()
    Serial.begin(115200);
    pinMode(5, OUTPUT);      // set the LED pin mode
    delay(10);
    // We start by connecting to a WiFi network
    Serial.println();
    Serial.println();
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
        delay(500);
        Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected.");
    Serial.println("IP address: ");
    server.begin();
int value = 0;
void loop(){
 WiFiClient client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
    Serial.println("New Client.");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("HTTP/1.1 200 OK");
            client.println("Content-type:text/html");
            client.println();
            // the content of the HTTP response follows the header:
            client.print("Click <a href=\"/H\">here</a> to turn the LED on pin 5 on.<br>");
            client.print("Click <a href=\"/L\">here</a> to turn the LED on pin 5 off.<br>");
            // The HTTP response ends with another blank line:
            client.println();
            // break out of the while loop:
            break;
          } else {    // if you got a newline, then clear currentLine:
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
        // Check to see if the client request was "GET /H" or "GET /L":
        if (currentLine.endsWith("GET /H")) {
          digitalWrite(5, HIGH);               // GET /H turns the LED on
        if (currentLine.endsWith("GET /L")) {
          digitalWrite(5, LOW);                // GET /L turns the LED off
    // close the connection:
    client.stop();
    Serial.println("Client Disconnected.");
It could be possible that my network is just week or something but I haven't had any problems with it before. I'm thankful for any help! :)
alanesq
Re: ESP32 WebServer doesn't respond / responds too late sometimes
Postby alanesq » Sat Sep 26, 2020 7:23 am
I have experienced this problem on my esp8266 projects and I resolved it by adding the command: WiFi.setSleepMode(WIFI_NONE_SLEEP);
I have not experienced it with esp32 but maybe the same issue?
lbernstone
Postby lbernstone » Sat Sep 26, 2020 1:43 pm
Two possible fixes:
1) Add WiFi.setSleep(false)
2) Add a delay(100) at the end of your loop()
Users browsing this forum: No registered users and 108 guests
