I've just downloaded the tool from the website and I am getting this error message.
I'm using a Windows10 64bit laptop
esp-idf-tools-setup-2.2.exe Installation has failed with exit code 1
Re: esp-idf-tools-setup-2.2.exe Installation has failed with exit code 1
I have attempted quite a few times now.
The error log appears fairly consistent no matter how many different Python versions and path options I try.
Snippet of error log included. Logs prior to this stage all show correct execution.
2020-02-29 12:28:24.360 --------
2020-02-29 12:28:24.360 Installing Python environment:C:\Users\RR\AppData\Local\Programs\Python\Python37\python.exe C:\Users\RR\esp-idf\tools\idf_tools.py install-python-env
2020-02-29 12:28:25.360 Done, exit code=1
2020-02-29 12:28:25.360 --------
2020-02-29 12:28:25.360 Running command: C:\Users\RR\AppData\Local\Programs\Python\Python37\python.exe C:\Users\RR\esp-idf\tools\idf_tools.py install-python-env
usage: virtualenv [--version] [--with-traceback] [-v | -q] [--app-data APP_DATA] [--clear-app-data] [--discovery {builtin}] [-p py] [--creator {builtin,cpython3-win,venv}] [--seeder {app-data,pip}] [--no-seed] [--activators comma_sep_list]
[--clear] [--system-site-packages] [--copies] [--download | --no-download] [--extra-search-dir d [d ...]] [--pip version] [--setuptools version] [--wheel version] [--no-pip] [--no-setuptools] [--no-wheel]
[--symlink-app-data] [--prompt prompt] [-h]
dest
virtualenv: error: unrecognized arguments: --no-site-packages
Creating a new Python environment in C:\Users\RR\.espressif\python_env\idf4.0_py3.7_env
File "C:\Users\RR\esp-idf\tools\idf_tools.py", line 1372, in <module>
main(sys.argv[1:])
File "C:\Users\RR\esp-idf\tools\idf_tools.py", line 1368, in main
action_func(args)
File "C:\Users\RR\esp-idf\tools\idf_tools.py", line 1184, in action_install_python_env
stdout=sys.stdout, stderr=sys.stderr)
File "C:\Users\RR\AppData\Local\Programs\Python\Python37\lib\subprocess.py", line 363, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['C:\\Users\\RR\\AppData\\Local\\Programs\\Python\\Python37\\python.exe', '-m', 'virtualenv', '--no-site-packages', 'C:\\Users\\RR\\.espressif\\python_env\\idf4.0_py3.7_env']' returned non-zero exit status 2.
2020-02-29 12:28:25.360 Message box (OK):
- ESP_krzychb
- Contact:
Hello gerrikoio,
From the log I see you are installing ESP-IDF 4.0. If so then:
1. Use https://dl.espressif.com/dl/esp-idf-tools-setup-2.3.exe
2. Let the installer download a fresh copy of ESP-IDF
This issue is discussed in more details in https://github.com/espressif/esp-idf/issues/4744
Ok, thanks.
I will do that and use esp-idf-tools-setup-2.3.exe.
I reinstalled using Python 3.7 instead of Python27 and everything installed successfully.
esp-idf-tools-setup-2.3.exe Installation works!
After failing the installation edit the file: ...\esp-idf\tools\idf_tools.py
In my case, it was the line 1183. Remove the argument '--no-site-packages' of the function.
The function looks like this before editing:
Edit it to look like this:
Try installing again using your previous installation folders.
subprocess.check_call([sys.executable, '-m', 'virtualenv', '--no-site-packages', idf_python_env_path],
subprocess.check_call([sys.executable, '-m', 'virtualenv', idf_python_env_path],
Users browsing this forum: Google [Bot] and 141 guests
