What to do if resolution in GATT not high enough?
SteaLTH_INSteaD
Postby SteaLTH_INSteaD » Mon Feb 24, 2020 3:37 am
Hi, For example let's says if I'm looking at height measurements which says it has a resolution in 0.01 meters, but I want 0.001 meter
https://www.bluetooth.com/wp-content/up ... height.xml
chegewara
Re: What to do if resolution in GATT not high enough?
Postby chegewara » Thu Feb 27, 2020 3:52 am
Maybe you can use non standard/SIG characteristic and send float value with resolution for C standard float?
IIRC you can also use descriptors to describe value in characteristic, with exponential number etc.
Users browsing this forum: No registered users and 168 guests
