I am trying to run the nvs examples from https://github.com/espressif/esp-idf/tr ... s_rw_value
when flash it on esp32 , i get the below error
▒▒▒▒▒▒▒▒***ERROR*** A stack overflow in task ipc1 has been detected.
abort() was called at PC 0x400853a0
Guru Meditation Error: Core 1 panic'ed (abort)
Backtrace: 0x40009203:0x3ffe7ce0 0x00000000:0x3ffe7d00 0x40082c18:0x3ffe7d20 0x40084a37:0x3ffe7d40 0x40083f40:0x3ffe7d60 0x40080ae0:0x3ffe7d80 0x40007c34:0x3ffe7dc0 0x40000740:0x3ffe7e30
can anyone let me know how to resolve this . I am using the latest esp idf library.
Thank you
Paul
stack overflow using nvs
Re: stack overflow using nvs
Just tried the sample with the latest master, and it seems to work okay...
Which development board are you using?
Can anyone else reproduce this?
Used Sparkfun-thing(ESP32) with MSYS comp. and flashed.(Win7)
I am using Sparkfun-thing(ESP32) on windows. Same stack overflow on both esp32.
We have reproduced an issue which is similar to it (although the output is not exactly the same). We'll have a fix for is in master shortly.
Users browsing this forum: No registered users and 78 guests
