atomic test and modify uint32_t
MarkZi
Postby MarkZi » Thu Mar 15, 2018 12:29 pm
what is the best way to do a atomic uint32_t operation. The uint32_t variable is only accessed by different freertos tasks, not by HW-ISR.
I do not know if the stdatomic.h stuff works.
I tried
uint32_t Can_ModifyUInt(uint32_t volatile *pUInt, uint32_t CompareValue, uint32_t NewValue)
  taskDISABLE_INTERRUPTS();
  uint32_t result = *pUInt;
  if (result == CompareValue)
    *pUInt = NewValue;
  taskENABLE_INTERRUPTS();
  return result;
but I'm unsure if that enough protection if the tasks runs on different ESP32-cores. And probably there is a more efficent solution than my code... :?
Any help is appreciated,
Mark
ESP_Angus
Re: atomic test and modify uint32_t
Postby ESP_Angus » Thu Mar 15, 2018 10:05 pm
Hi Mark,
C stdatomic will work correctly, including across cores.
The code you posted will only work if all accesses are made from tasks running on the same core.
You can also use our port-specific FreeRTOS uxPortCompareSet() macro:
https://github.com/espressif/esp-idf/bl ... cro.h#L273
(This macro uses the same Xtensa atomic test-and-set instruction that the compiler will generate for stdatomic operations.)
If you need higher level concurrency primitives, take a look at FreeRTOS mutexes, semaphores, etc.
raldone01
Postby raldone01 » Sat Jan 25, 2020 11:29 am
Hi ESP_Angus,
Don't point links to files in the master branch as it changes. (The line is not correct anymore.)
rustyx
Postby rustyx » Mon Jul 12, 2021 8:10 am
Too bad ESP8266 doesn't seem to fully support std::atomic. Atomic loads/stores work fine, but compare_exchange_weak(), compare_exchange_strong(), ++, etc, end up with a link error "undefined reference to `__atomic_compare_exchange_2`".
Of course it's not an issue on a single-core system. But it requires conditional compilation in portable ESP8266/ESP32 code.
ESP_igrr
Postby ESP_igrr » Mon Jul 12, 2021 8:30 am
Hi rustyx,
The recent version of stdatomic.c from ESP-IDF provides all necessary atomic built-in functions also on single core chips: https://github.com/espressif/esp-idf/bl ... tdatomic.c
You can try to copy this file to your ESP8266 project. It might need a few tweaks to spinlock-related macros (portENTER_CRITICAL) for the ESP8266 RTOS SDK or non-OS SDK, depending on what you are using.
Users browsing this forum: Bing [Bot] and 95 guests
