Hi all,
I have been reading this forum and everything on the internet regarding to the modem sleep with BLE and adding an external crystal for keeping the BLE alive.
I have taken a look to this thread where they speak about this: https://github.com/espressif/esp-idf/issues/947
But every post I find is about esp32-idf and the code is different from the arduino esp32 because I can´t find many functions they speak about. I did active the power manager, but I am not able to get anything better than 60-80mAh, and I have read people getting 30mAh, how can they get it?
I haven´t used the external crystal yet, but even If I add it, I wouldn´t be able to activate it an use it as people use it in esp32-idf because as I have already said, many functions are not available for the arduino esp32.
Is there any idea for getting lower currents?
Is it expected a new version for helping with the power consumption?
Thank you so much for your time,
Cheers.
BLE power consumption and modem sleep
Re: BLE power consumption and modem sleep
https://docs.espressif.com/projects/esp ... index.html
its not that you cant use esp-idf functions in arduino to control bluetooth and/or light/deep sleep, its just those functions are not wrapped in BLE library. Post you found on github is best start and more info you can find here:I haven´t used the external crystal yet, but even If I add it, I wouldn´t be able to activate it an use it as people use it in esp32-idf because as I have already said, many functions are not available for the arduino esp32.
Thanks for the link but I already now about all the documentation. So as you say, many functions like the power managment control are not wrapped in the esp32 arduino core. Is there a way for wrapping them? I imagine that if they are not wrapped in yet, it must be for a reason.chegewara wrote: ↑Fri Dec 20, 2019 12:46 pmHi,its not that you cant use esp-idf functions in arduino to control bluetooth and/or light/deep sleep, its just those functions are not wrapped in BLE library. Post you found on github is best start and more info you can find here:I haven´t used the external crystal yet, but even If I add it, I wouldn´t be able to activate it an use it as people use it in esp32-idf because as I have already said, many functions are not available for the arduino esp32.
Thank you so much!
Only reason they are not wrapped is that noone wanted it before working with this library. You can add functions to use esp-idf API from within BLE library or you can use esp-idf API alongside arduino BLE library.
Did you have any success?
Users browsing this forum: lbernstone and 27 guests
