ESP-Azure include in existing project
zipfelchaeppli
Postby zipfelchaeppli » Mon Dec 09, 2019 1:01 pm
Dear all,
I would like to include esp-azure into an existing idf-project.
The structure is as follows:
components
--drv
----drv1.c
----drv1.h
--com
----wlan.c
----wlan.h
esp-azure
---- [All files/folders from https://github.com/espressif/esp-azure]
main
--main.c
If I compile, an example inside esp-azure, it compiles with no problems.
However, if I compile my project as above and include "iothub_client.h" in my main.c., I get the error, that the h-file could not be found.
How do I need to include the esp-azure component such that I can use "iothub_client.h" in my project?
Thank you in advance for any help or hint!
Best,
Jonas
jsam589
Re: ESP-Azure include in existing project
Postby jsam589 » Mon Dec 16, 2019 3:32 am
I have just been doing this same thing. Here are several findings that help me.
1. If you are using CMake, for example with v4.x of IDF, try adding this EXTRA_COMPONENT_DIRS line in the project top-level CMakeLists.txt file. I got this from one of the esp-azure examples and just changed the relative path. Without this line I was seeing the same #include errors you mention.
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
set (EXTRA_COMPONENT_DIRS "${CMAKE_CURRENT_BINARY_DIR}/../components/esp-azure/port")
project(wifi_station)
2. If you need provisioning client code to be included (by #defining USE_PROV_MODULE), the "correct" way to define this is to define CONFIG_DEVICE_COMMON_NAME. I did this by adding file Kconfig.projbuild in main/ folder with this content.
    config DEVICE_COMMON_NAME
        bool "Azure x509 Support"
        default y
        help
            Select this, Azure port lib will define HSM x509.
If you add it, these lines in the esp-azure top-level component.mk file will be affected by that change:
ifdef CONFIG_DEVICE_COMMON_NAME
CFLAGS += -DUSE_PROV_MODULE
endif
3. I use symbolic links to include esp-azure in my project directory. I like to keep the very large esp-azure directory out of my actual repository. Sym links work well on Linux and Windows. To the IDF build tools, symbolic links look like any other folder under components/.
4. I use the "1.0" ESP Azure port and have not had to change anything in it. I do have some runtime issues when building against v4.x IDF, but not when building against v3.3, so I don't think it's a problem with the esp-azure port. I am about to post a forum question on that issue.
5. Finally, the library created for the entire esp-azure is call libport.a, a very innocuous name not indicative that this is for the huge azure component. But if you are perusing your map file, this is where all the esp-azure stuff resides.
./build/esp-idf/port/libport.a
jsam589
Postby jsam589 » Mon Dec 16, 2019 4:28 am
Link to my description re: provisioning handshaking problem when using v4.x IDF. Even if you get yours to build, it might not fully communicate if you are building against 4.x IDF.
viewtopic.php?f=22&t=13533
Users browsing this forum: No registered users and 14 guests
