How to send a signal through 2 wires using rmt.h ?
GeorgeFlorian1
Postby GeorgeFlorian1 » Thu Dec 12, 2019 2:20 pm
Board: ESP32-EVB
OS: Linux Mint
Hello !
For the past week, I have been trying to send this binary number: 01100000101111001011111000 through two wires, emulating the Wiegand Protocol, to a Card Reader.
Wiegand Protocol starts with both pins HIGH. When I send a 0, W0 pin is pulled LOW for usually 20-100us and W1 stays HIGH. When a 1 is being sent W1 is pulled LOW for usually 20-100us and W0 stays HIGH.
I have been able to send that number by doing this:
void setup() {
  Serial.begin(115200);
  pinMode(W0, OUTPUT);
  pinMode(W1, OUTPUT);
  digitalWrite(W0, HIGH);
  digitalWrite(W1, HIGH);
void loop() {
  delay(100);
  if(change) {
    Serial.println("Sending ID...");
    pulse = pulseWidth.toInt();
    portMUX_TYPE mux = portMUX_INITIALIZER_UNLOCKED;
    portENTER_CRITICAL(&mux);
    for(int i = 0; i<26; i++) {
      if(wiegandArray[i] == 0) {
        digitalWrite(W0, LOW);
        delayMicroseconds(pulse);
      } else {
        digitalWrite(W1, LOW);
    portEXIT_CRITICAL(&mux);
  if(change) {
    change = false;
      Serial.print(wiegandArray[i]);
    Serial.println();
The problem with this is that it isn't reliable. It won't work all the time.
I've then tried implementing it in a task:
void taskOne(void * parameter ) {
  for( ; ; ) {
    if(change) {
      int pulse = pulseWidth.toInt();
      vTaskSuspendAll();
        } else {
      xTaskResumeAll();
      if(change) {
        change = false;
        Serial.println();
      uxTaskGetStackHighWaterMark(NULL);
    } // if(change)
  } // for( ; ; )
void setup() {
  xTaskCreate(
              taskOne,          /* Task function. */
              "TaskOne",        /* String with name of task. */
              10000,            /* Stack size in bytes. */
              NULL,             /* Parameter passed as input of the task */
              1,                /* Priority of the task. */
              NULL);            /* Task handle. */
void loop() {
delay(100);
But this doesn't do anything.
Now, I am being told to try the RMT driver, that can only send one signal through one pin at a time, but I need one signal through two pins, which can apparently be done by doing this:
If you need to split the signal on the output you can do that via NPN/PNP transistors to create an inverse signal or direct the output to two outputs based on the high/low state of the single output.
But, I have no idea how to use transistors. Will I have to split the signal by 0 and 1 in code or from hardware ? How is the split happening ?
I want to send 01100000101111001011111000. Do I send it all at once with a little pause between each one of the bits and the transistor will split the signal and send the zeros (0) to a pin, the ones (1) to the other pin and hope that they will be synchronized ? Because I can't have 0 and 1 sent at the same time.
Can I get some help in understanding how this works and how can I implement it ?
Thank you.
tommeyers
Re: How to send a signal through 2 wires using rmt.h ?
Postby tommeyers » Thu Dec 12, 2019 8:09 pm
Take a look here: https://www.arduinolibraries.info/libra ... nd-library
In the in file there is a readme that describes the protocol.
Maybe the code could be adapted to your project.
Tom Meyers
IT Professional, Maker
Santiago, Dominican Republic
GeorgeFlorian1
Postby GeorgeFlorian1 » Fri Dec 13, 2019 8:56 am
Tom Meyers
This is at the beginning of the readme:
# Yet Another Arduino Wiegand Library
A library to received data from Wiegand RFID Card readers.
All of the examples I could find are similar to this one. They are all Wiegand Readers/Receiver and I want a Wiegand Writer/Transmitter/Sender.
tommeyers
Postby tommeyers » Fri Dec 13, 2019 2:04 pm
Goerge,
Oops, I read through that too quickly.
Here is another try an transmitting: https://www.codeproject.com/Articles/12 ... th-Arduino
I thought it would be necessary to invert the second line from the first. This shows how to wiggle each line in code.
Tom Meyers
GeorgeFlorian1
Postby GeorgeFlorian1 » Tue Dec 17, 2019 9:22 am
Goerge,
Tom Meyers
I have already achieved the same results in my project:
      } else {
The problem with this is that it won't work 100% of the time, because of the FreeRTOS scheduler that will interfere and can screw up the signal.
tommeyers
Postby tommeyers » Tue Dec 17, 2019 9:08 pm
George i don't see the similarities with this code:
void outwiegbit(unsigned int b)
int sel = b == 0 ? W_D0 : W_D1;
digitalWrite(sel, 0);
delayMicroseconds(80);
digitalWrite(sel, 1);
delayMicroseconds(240);
You wiggle one or the other. This wiggles both at the same time. See what think.
Tom
Users browsing this forum: No registered users and 66 guests
