[SOLVED] Trouble with HTTP GET
RudolfAtRTC
Postby RudolfAtRTC » Wed Dec 11, 2019 10:12 am
I'm working on a WEB server at a ESP32 to control a 3-color-LED.
- The color picker ("colorpicker") from HTML5 is working
- I can input a color with an input field named "selectedcolor"
- But no GET request is done when the button (named "button") is pressed!
- I do'nt use a form
Can I get help to find my mistake?
  1. /*======================================================================
  2.     WEB-Server with NodeESP (ESP32) - Set colours for a 3-color-LED
  3.     ----------------------------------------------------------------------
  4.     Base:
  5.   Rui Santos: Complete project details at http://randomnerdtutorials.com
  6.     ----------------------------------------------------------------------
  7.     Author: Rudolf Schenke (aus Basis Rui Santos)
  8.     Stand: 10.12.2019
  9.     ======================================================================*/
  10.
  11. bool xDebug = true;     // Debug when true
  12.
  13. #include <WiFi.h>               // Load Wi-Fi library
  14.
  15. //---- WLAN-SSID and password - later from a file ----
  16. const char* ssid     = "...";
  17. const char* password = "....";
  18.
  19. WiFiServer server(80);  // Set web server port number to 80
  20.
  21. String header;  // Variable to store the HTTP request
  22.
  23. // Auxiliar variables to store the current output state
  24. String stateBlue = "Aus";
  25. String stateGreen = "Aus";
  26. String stateRed = "Aus";
  27.
  28. // Assign output variables to GPIO pins
  29. const int pinBlue = 0;
  30. const int pinGreen = 2;
  31. const int pinRed = 4;
  32.
  33. void setup() {
  34.
  35.   Serial.begin(115200);
  36.     while(!Serial) delay(10);
  37.     Serial.println("WEB-Server zum Ein-Ausschalten der 3-Farben-LED");
  38.
  39.   // Initialize the output variables as outputs
  40.   pinMode(pinBlue, OUTPUT);
  41.   pinMode(pinGreen, OUTPUT);
  42.   pinMode(pinRed, OUTPUT);
  43.   // Set outputs to LOW
  44.   digitalWrite(pinBlue, HIGH);
  45.   digitalWrite(pinGreen, HIGH);
  46.   digitalWrite(pinRed, HIGH);
  47.
  48.   // Connect to Wi-Fi network with SSID and password
  49.   Serial.print("Connecting to ");
  50.   Serial.println(ssid);
  51.   WiFi.begin(ssid, password);
  52.   while (WiFi.status() != WL_CONNECTED) {
  53.     delay(500);
  54.     Serial.print(".");
  55.   }
  56.   // Print local IP address and start web server
  57.   Serial.println("");
  58.   Serial.println("WiFi connected.");
  59.   Serial.println("IP address: ");
  60.   Serial.println(WiFi.localIP());
  61.   server.begin();
  62. }
  63.
  64. void loop(){
  65.   WiFiClient client = server.available();   // Listen for incoming clients
  66.
  67.   if (client) {                       // If a new client connects,
  68.     Serial.println("New Client.");    // print a message out in the serial port
  69.     String currentLine = "";          // make a String to hold incoming data from the client
  70.     while (client.connected()) {      // loop while the client's connected
  71.       if (client.available()) {       // if there's bytes to read from the client,
  72.         char c = client.read();       // read a byte, then
  73.         if (xDebug) Serial.write(c);    // print it out the serial monitor
  74.         header += c;
  75.         if (c == '\n')
  76.                 { // if the byte is a newline character
  77.           // if the current line is blank, you got two newline characters in a row.
  78.           // that's the end of the client HTTP request, so send a response:
  79.           if (currentLine.length() == 0)
  80.                     {
  81.             // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
  82.             // and a content-type so the client knows what's coming, then a blank line:
  83.             client.println("HTTP/1.1 200 OK");
  84.             client.println("Content-type:text/html");
  85.             client.println("Connection: close");
  86.             client.println();
  87.
  88.                         //---- Hier muss die Auswertung rein! ----
  89.                         Serial.println("Auswertung fehlt!");
  90.
  91.             // Display the HTML web page
  92.             client.println("<!DOCTYPE html><html>");
  93.             client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
  94.             client.println("<link rel=\"icon\" href=\"data:,\">");
  95.                         client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}</style>");
  96.             client.println("<title>HTML5 Color Picker Demonstration</title>");
  97.
  98.             client.println("<script language=\"javascript\">var actColor; function newColor(color)");
  99.             client.println("{ document.getElementById(\"selectedcolor\").value = color; ");
  100.             client.println("actColor = color;");
  101.             client.println("console.log(actColor); ");
  102.             client.println("document.getElementById(\"button\").href=\"/\" + actColor + \"&\"; }");
  103.
  104.             client.println("function setColor(color)");
  105.             client.println("{ document.getElementById(\"colorpicker\").value = color; ");
  106.             client.println("actColor = color;");
  107.             client.println("console.log(actColor); ");
  108.             client.println("document.getElementById(\"button\").href=\"/\" + actColor + \"&\"; }");
  109.
  110.             client.println("</script></head>");
  111.
  112.             // Web Page Body
  113.             client.println("<body><h1>NodeESP Web Server</h1>");
  114.             client.println("<h2>Color Picker f&uuml;r 3-Farben-LED</h2>");
  115.             //---- Form mit Farbpicker und Anzeige Farbwert ----
  116.             client.println("<p>Farbe ausw&auml;hlen: ");
  117.             client.println("<input id=\"colorpicker\" type=\"color\" ");
  118.             client.println("onchange=\"newColor(colorpicker.value);\"></p>");
  119.             client.println("<p>Ausgew&auml;hlt: <input id=\"selectedcolor\" type=\"text\" ");
  120.             client.println("onchange=\"setColor(selectedcolor.value);\"></p>");
  121.
  122.             client.println("<p><a href=\"#\" id=\"button\" role=\"button\">&Uuml;bernehmen</a></p>");
  123.
  124.             client.println("</body></html>");
  125.
  126.             // The HTTP response ends with another blank line
  127.             client.println();
  128.             // Break out of the while loop
  129.             break;
  130.           }
  131.                     else
  132.                     { // if you got a newline, then clear currentLine
  133.             currentLine = "";
  134.           }
  135.         }
  136.                 else if (c != '\r')
  137.                 {  // if you got anything else but a carriage return character,
  138.           currentLine += c; // add it to the end of the currentLine
  139.         }
  140.       }
  141.     }
  142.     // Clear the header variable
  143.     header = "";
  144.     // Close the connection
  145.     client.stop();
  146.     Serial.println("Client disconnected.");
  147.     Serial.println("--------------------");
  148.   }
  149. }
Re: Trouble with HTTP GET
Postby ESP_Sprite » Thu Dec 12, 2019 3:29 am
(also, no JS to do AJAX, looking at your code)
Then why do you expect a GET request to be generated?
RudolfAtRTC
Postby RudolfAtRTC » Thu Dec 12, 2019 3:35 pm
Yes - you are right! I have changed to a "form" and it works now. Learning by doing....
Users browsing this forum: No registered users and 52 guests
